transmition went bad:(
Old November 19th, 2008, 08:31 PM   #1
unblock is on a distinguished road
i was cruising around 20 and i pushed it hard that it shifted from 4th to 1 and took my foot of the gas and stopped to talked to a friend when i stopped the car was shaking a bit when i later started teh car and moved on i felt like the gears were slipping till i came to a complete stop then i was not able to drive more than 5mile an hour when ever i give it more gas it was like the gear is in N , it doesn't matter if its in 1 or 2 or D , how ever in R the car rever fine with no problem :s
what could be the problem ? is it sum thing hard and expensive to fix?
Old November 20th, 2008, 12:30 AM   #2
Shake Me Like A Monkey
Triple A's Avatar
Triple A has much to be proud ofTriple A has much to be proud ofTriple A has much to be proud ofTriple A has much to be proud ofTriple A has much to be proud ofTriple A has much to be proud ofTriple A has much to be proud ofTriple A has much to be proud of
check the tranny fluid level
Old November 20th, 2008, 12:33 AM   #3
zinc02GT's Avatar
2011 Mustang GT
12.1 @ 116
zinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud of
Learn how to put correct puncuation and I might able to help you. I have no clue what you just said...
Mods in garage. New mods, new track times soon.
Old November 20th, 2008, 12:38 AM   #4
Triple A's Avatar
lol
Old November 20th, 2008, 01:16 PM   #5
03FstStngKB's Avatar
2003 Ford Mustang GT
After Stall'd>>13.50??
03FstStngKB is on a distinguished road
Learn how to put the correct puncuation in and I might be able to help you. I have no clue what you just said...
^^^^just messing with ya...lol...I don't have room to talk myself though...mines horrible
To the OP you might have some major problems? Downshifting out of 4th to 1st is pretty hard on the transmission. You are in overdrive and it's never good to downshift or upshift at WOT from that gear to any gear for that matter, or as you put it "very hard" out of that gear.
Being cheap depends on how you look at? Once you diagnosis it as a mechanical failure then it's wise to spend the extra money to beef it up so that you are not in the same boat next time. But you can get used ones pretty cheap from the junkyard.
^^^^^^^^^My other BaBy!!!^^^^^^^^^
<---Mods List--->
4.30 Gears Installed
Mac H-Pipe Installed
40 Series Flowmasters Installed
Diablo Predator Tuned
Coming soon>>>SCT Tuned
J-mod and 3700 Stall >> ET of completion 'Spring or Summer of 09'
Old November 20th, 2008, 03:22 PM   #6
~C~
~C~, The Other White Meat!
~C~'s Avatar
Y2K YellowJacket GT
~TBD~
~C~ is just really nice~C~ is just really nice~C~ is just really nice~C~ is just really nice
Send a message via AIM to ~C~
Agreed. Thanks.
BLOWN Bumblebeast!
370 rwhp / 381 ft lbs
~Tuned by JJ at WMS
"Like the blind man says......We shall see...."
Old November 20th, 2008, 03:24 PM   #7
Randy Stinchcomb's Avatar
1996 Mustang GT coupe
11.99@113.93mph
Randy Stinchcomb will become famous soon enough
sheees and I thought it was just me
Thumbdinger.com Fish With Protection
Old November 20th, 2008, 04:13 PM   #8
2kGT's Avatar
2kGT has a little shameless behaviour in the past
Time to get rid of that girly ass auto and put a manual in.
Accufab 75mm tb & plenum
MRT h-pipe
Flowmaster catback
FRPP king cobra clutch
FRPP aluminum driveshaft
FRPP 4.10 gear
TA Perfromance girdle
Steeda tri-ax shifter
Moser 31 spline axles
FRPP C Springs
Old November 20th, 2008, 05:11 PM   #9
02 mineral grey GT
SORC 29 miles 13 mins 14 secs
Exodus is on a distinguished road
Old November 20th, 2008, 05:12 PM   #10
Triple A's Avatar
agreed
reps
Old November 21st, 2008, 12:33 AM   #11
would be too expeinsive to swap to a stick
Old November 21st, 2008, 05:26 AM   #12
1998 mustang gt vert
98stanger is on a distinguished road
Send a message via AIM to 98stanger Send a message via Yahoo to 98stanger
well worth it though and alot more fun to drive
check out my garage for info
Old November 21st, 2008, 12:02 PM   #13
oh2swapped's Avatar
02 Mustang GT
17.8@52
oh2swapped is on a distinguished road
too expensive....i picked up a 2002 GT that some idiot put into a tree on the passenger door for 2,000. motor and tranny were fine and only had 16,000 miles on it.. thats how i did my swap so cheap. you just gotta look around and you can find pretty much anything.
NEXT TO SEX, MY MUSTANG IS BEST
Threads Similar to: transmition went bad:(
Bad...Gators...Bad oldernewbie The Clubhouse 3 November 15th, 2008 05:58 PM
IAC BAD??? OR throttle body bad? Rico-mofos 99-04 10 March 12th, 2008 07:32 PM
Bad Wheelie Gone Bad... CAMN89GT The Clubhouse 7 November 16th, 2007 08:37 AM
Bad Bad Bad situation mustangmanic The Clubhouse 32 October 26th, 2007 11:55 PM
bad bad wreck 232stang The Clubhouse 12 April 8th, 2007 01:37 PM
