Stock spring isolators
So I'm not buying my full coilover suspention next year because of some other things that are on my list as i'm graduating high school and opening the new karate school to teach at. very very busy.
but i really want to get rid of as much 4x4 look as possible. can i just remove the stock spring isolators without doing any other suspenion mods? i've tried searching on this, no luck. any input greatly appriciated thanks!
___________ ![]() 0hp 0tq |
13.58 @ 102.31
![]() ![]() iTrader: 5 reviews
I don't see why you couldn't? I would just look for some used lowering springs or buy a cheap set of eBay ones though , you'll only lower the car 1/4" by taking them out and reusing the stock springs.
1989 LX
12.60 at 109mph
i was thinkin onb taking mine off but i don't want them to make noise i was thinkin either putting some electrical tape or something
1989 LX mustang, 5speed, 108,xxx miles, Mac Longtubes, BBK midpipe, Paxton Novi 1000 6psi, Crappy FMU with 19lb injectors, 373 gears soon to come 30lb injectors, Blow through MAF, intercooler and tune |
Abyssinian of AX
'02 Saleen
19.34@42.259
They won't make noise, but only lower you approx 3/8" in rear and maybe 5/8" up front. Just install a bit of heavy grease at contact points and will be fine.
I agree with others that it probably wouldn't be worth the trouble to do so w/o replacing springs. HTH Jazzer |
1989 LX
12.60 at 109mph
oh i got the eibach lower spring the front is perfect back the rear is not that low and what a bit more? i think im just gonna put like two layers of tape and a lil grease then i will be fine lol
04 mustang gt
7.21 @ 98
i had the same problem. front is perfect...but rear sits high. think i will take out the rear isolators. if that don't work then i'm getting new springs. it drives me crazy.
![]() cams + 150 shot |
13.58 @ 102.31
just take out the top rear iso?
2000 Mustang Gt
That's what I did. I was happy with how the front sat. But the rear was a little too high, so I removed the top rear iso. I didn't use any grease or tape...and all is good!
![]() Tuned by Joe at Tricktuners.com |
#9 | |
Abyssinian of AX
'02 Saleen
19.34@42.259
No need to bother with the tape. I ran my car for 20 years w/o the isolators and just a bit of heavy grease in the perches. You will get some additional road noise as it is the spring-pads job to reduce such things. I had no squeeking or issues for the entire time. HTH Jazzer |
Threads Similar to: Stock spring isolators
| Removing spring isolators | Texas01GT | 99-04 | 12 | July 1st, 2008 02:36 PM |
| front spring isolators? | fakesaleen | 5.0 Mustangs | 0 | June 22nd, 2008 10:19 AM |
| How important are spring isolators? | Muscletang | General Tech | 4 | January 31st, 2008 10:51 AM |
| Spring Isolators | mustangdrvr2019 | V6 Mustangs | 2 | October 2nd, 2006 08:36 AM |
| What is the pros and cons of urethane spring isolators? | JAY'SRED02 | General Tech | 7 | August 17th, 2006 03:22 AM |
