Trans gets stuck in reverse?
Old November 23rd, 2008, 07:22 PM   #1
99mustanggtman's Avatar
1999 GT
99mustanggtman will become famous soon enough
iTrader: 7 reviews
Send a message via AIM to 99mustanggtman
this is about the 3rd time its ever happened. First time was about 2 weeks ago and today it happened twice. When I go into reverse, it is stuck in gear and I can't push it out of gear. I literally had to kick it as hard as I could with my foot to get it out of gear. All other gears 1-5 have never gotten stuck in gear. I am positive its something internally wrong with the trans.
Whats the cause of this?
btw: Its a 99 GT w/ 74xxx miles. The trans occasionally grinds 3rd and 4th gear.
Single 67mm turbo, ported pi heads, edelbrock vic jr. manifold w/HPP plenum, terminator shortblock, return fuel system... Goal 600+ rwhp.
Old November 23rd, 2008, 07:51 PM   #2
Abyssinian of AX
Jazzer The Cat's Avatar
'02 Saleen
19.34@42.259
Jazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant future
I used to have a Vega (< OK, you can stop laughing now, I was in HS at the time) Anyway, the synchros used to fail and would get stuck in 3rd gear. The first time it happened, I took it out and took the bottom off on my work bench. It rolled over during inspection and popped out of 3rd. I messed with it for an hour and could not figure out why it got stuck, but was "fine" now.
I re-installed it and got stuck again 2 days later
I am guessing syncros in yours as well.
Jazzer
Un-Official Suspension Guide | Choosing a new tire | Brakes upgrade ~ Speeding up slowing down | T-3650 ~ T-56 swap | Tire and Wheel Fitment Guide | The Kitty makes front page news
Originally Posted by Novanutcase View Post
"... although Jazzer's view is a little skewed since he pushes his car HARD so his opinion as to what works is more rooted in extreme circumstances!
Old November 23rd, 2008, 07:58 PM   #3
JayC's Avatar
2001 Mustang GT
JayC has a spectacular aura aboutJayC has a spectacular aura aboutJayC has a spectacular aura about
My T-45 has also done that a couple of time. Once it pops back out it's fine until it happens again...... sometimes months later. I have no answers for you though
tuned by SPEEDY DYNO
12.41 @ 109 mph w/ CMS stage II cams
11.13 @ 122 mph NX 150 shot
Launch soft, shift slow, rev low, stay slow
Old November 23rd, 2008, 08:17 PM   #4
zinc02GT's Avatar
2011 Mustang GT
12.1 @ 116
zinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud of
Do you have a short throw shifter? Also, clutch good?
If no shoft throw and clutch is fine, then it can be your synchros/blocking rings. When my synchro went out in 3rd gear, my mechanic said for me to put it into 3rd gear and floor it untill 5000rps. He said for me to pull it out of gear right near 5000rpms when the most amount of stress is going on. He said that if I couldn't pull it out of gear at that point, I had shaved my blocking ring my blocking ring teeth and that the sycnhros in turn would also be gone.
It came outta gear, so the diagnosis was just my synchro. But it turned out when he got into the transmission that because the synchro failed it would 'hop; and grind into the edge of 3rd gear. I had to get the gear and everything replaced.
Mods in garage. Built suspension and gears since posted times.
Old November 23rd, 2008, 09:33 PM   #5
JayC's Avatar
2001 Mustang GT
Reverse has no syncros in a T-45
Old November 23rd, 2008, 10:09 PM   #6
1999 GT
iTrader: 7 reviews
it may be bent shift keys in the reverse slider assembly.
Threads Similar to: Trans gets stuck in reverse?
OMG i'm stuck in reverse! knightof206 Modular Mustangs 8 October 12th, 2008 11:32 PM
Reverse ? HMUSN The Clubhouse 5 July 10th, 2008 07:49 PM
Reverse? Killax15 99-04 7 May 9th, 2008 08:30 PM
Reverse Lights?? (Trans Swap) the real shocker 99-04 2 December 27th, 2007 10:45 PM
Auto Trans Problem - Stuck in Park on my AOD Sir Charles 96-98 10 July 10th, 2007 10:03 PM
