need help! moser axles!
LinkBack (1) Thread Tools
Old November 27th, 2008, 10:09 PM   1 links from elsewhere to this Post. Click to view. #1
mystang0673's Avatar
6.82@100mph 1.45 60'
mystang0673 has a spectacular aura aboutmystang0673 has a spectacular aura aboutmystang0673 has a spectacular aura about
ok guys here goes. a few weeks ago i had my rear end built... mmr differential, moser axles, ford gears... the night i got the car back it sounded like it had a small brake squeak... well.. i figured it would go away but it didnt... so i took the wheels off and this is what i found... 1. the axles moved in and out somewhere between 1/4-1/2 an inch... 2. the caliper brackets were shimmed out with a washer to keep the rotors dead center of the caliper brackets... well... by brakes are squeaking horribly.... i have put anti squeal on EVERY part where metal touches metal except where the pads touch the rotors... my buddy installed some moser axles in his mach one and they squeaked and his rotors were warped after doing some burn outs so he had them turned and it fixed the problem...... i figure i might have warped the rotors after this past sunday at the track and that may be the problem.. any of you had this problem? any of you had to space the brackets out because of the axles being too long?
Old November 27th, 2008, 10:22 PM   #2
PapaSmurf's Avatar
2003 Mustang GT
12.28 @ 116
PapaSmurf has a spectacular aura aboutPapaSmurf has a spectacular aura about
iTrader: 13 reviews
Ive never heard of people having problems with this. My mosers are going in next friday along with my gears and diff. I hope i dont experiance this.....
2003 Sonic Blue GT---SLP Longtubes, SLP X, Magnaflow Magnapack CB, 75mm TB/Plenum, MP2 Performance stage 2 heads, MHS Stage 3R cams, Built rear w/4.30's
Old November 27th, 2008, 10:27 PM   #3
Proud American
MustangMatt96GT's Avatar
They put the C Clips back in? axles should not move in and out from what i know.
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
25.3 SFI Chassis Build
Never Lift Racecars
Old November 27th, 2008, 10:31 PM   #4
yes... the axles wont come completely out with the brakes off... whereas if he forgot the c clip it would come out with brakes off... and i have been told its supposed to have a little play... but i dunno if its supposed to be that much. im gonna turn my rotors the first thing in the morning and if that doesnt fix it im gonna pull the axles out and see what i can figure out...
Old November 27th, 2008, 11:05 PM   #5
PapaSmurf's Avatar
2003 Mustang GT
12.28 @ 116
iTrader: 13 reviews
Sounds like the installer did something wrong because i have never heard of this happening. Let us all know what you find out bro.
Old November 28th, 2008, 02:48 PM   #6
i fixed the problem... the drivers side caliper bracket needed to be spaced out a tad more... i dont know if he used explorer axles because i have heard that they are longer.. but these axles were brand new from moser. dont know why he would have done that. he said the last few set of axles he has bought have been a tad bit long.. oh well. i fixed my problem so...
Old November 28th, 2008, 03:15 PM   #7
PapaSmurf's Avatar
2003 Mustang GT
12.28 @ 116
iTrader: 13 reviews
thats so weird. Where did you buy your mosers from? I got mine for american muscle, they are getting installed friday
Old November 28th, 2008, 03:26 PM   #8
i didnt buy them. the guy that installed them did.. its cool now.. i dont really care, as long as they dont break. lol. sad thing is, i cut a better 60' on stock axles, gears, 17" wheels and drag radials than i did with axles, gears, slicks on 15" wheels. lol
Old November 28th, 2008, 05:16 PM   #9
01gtMustang132's Avatar
2001 Mustang GT
13.15@101
01gtMustang132 is on a distinguished road
He might have bought the wrong axles...
70-93 29 3/16 long (MSR-A883151) All 5lug 31 spline
94-98 29 31/32 long (MSR-A883152) "
99-04 30 11/16 long (MSR-A883153) "
I have never herd of shimming brake calipers...( the right axles no problems)
My axles move maybe about 1/8 inch back and forth...
Never had a problem...
Old November 28th, 2008, 06:28 PM   #10
here is the thing.. the axles for the 99-04 8.8 are the longest made for a ford.... and thats what i have... the caliper brackets are what were shimmed... the reason is because when the axles move in and out whether it be 1/8 or 3/16, the rotor hits the caliper bracket.. so they were shimmed to center the rotor in the bracket.
Old November 28th, 2008, 11:03 PM   #11
2000 GT
RyanGT is a jewel in the roughRyanGT is a jewel in the roughRyanGT is a jewel in the rough
Some of these axles are adjustable. Im not sure how they do adjust but maybe whatever he did he left it out (not sure if its bolted or clip or whatnot).
2000 Black convertible GT: KB 15psi, and other goodies...
1971 Datsun 240 z: Header and rebuilt motor. (The DD)
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/99239-need-help-moser-axles.html
Moser axles: a touch too wide. - Ford Mustang Forums : Corral.net Mustang Forum This thread Refback April 19th, 2012 09:36 AM
Threads Similar to: need help! moser axles!
Moser Axles blackhavok 2005 - 2010 18 June 17th, 2008 10:01 AM
Moser 1999-2004 MUSTANG COBRA 31 spline C-Clip Axles gills99stang 99-04 0 March 27th, 2008 06:40 PM
Strange or Moser 31 spline axles? 03 R Code General Tech 20 September 5th, 2007 11:51 AM
Moser 31 spline axles orangeRcode 4V / SVT 14 February 6th, 2007 10:47 PM
