2001 Mustang GT
Wtf Is Going On With My Car?
i own a 2001 automatics gt, i have 4.10's,sct xcal3, bbk 78mm throttlebody/plenum,bbk cai, saleen udp, pypes x-pipe, and magnapacks. last night i drove an hour to get home from familys house, then drove another 30 mins to a different city to get some runs in, then ran my car 2 times, then on the way back home i was doing 50mph pulls on the freeway with my friend in his STI, i noticed that for some reson everytime my car shifts from 3rd-4rth it goes into redline and bounces off the rev limited 2 times before shifting, also i notice when going that fast something is vibrating under my car a lot, i ask my friend what he thinks and he said it was my drive shaft, THEN when we are at a light in the city my friend tells me that when my car was shifting from 3rd-4rth a huge cloud of black smoke came out of my tail pipes(hence i was in front the whole time
), and it didnt just happen for a quick second, black smoke would come from my tail pipes for a good 4-5 seconds before stopping,all advice suggestions are appreciated thanks in advance
04 mustang gt
7.21 @ 98
i dunno...but who won...you or sti?
![]() cams + 150 shot |
2004 mustang GT
idk but could it be that the black smoke was just because u were on the rev limiter?
flowmasters, no cats, 3.73's, sct xcal2, eibach pro kit, CC plates, 75mm TB, plenum, T56 Cobra manual transmission,and last but not least a procharger P1SC. 400hp and 376ft-lbs |
13.58 @ 102.31
![]() ![]() iTrader: 5 reviews
your car could be running rich, do you know your a/f ratio? And that tb and plenum is huge for a n/a bolt on car. I'm not sure about you shifting problem though, did you mess with the shift points while tuning your car??
2001 Mustang GT
i beat the STI by 2-3 cars everytime
![]() i was thinking about the tuner but i didnt mess with my shift points at all but i think i might to see if that fixes my problem, its buggin me because i am hesitant to spray now, i can be bouncing of the rev limiter while spraying
07 gt
you wont be bouncing off the limiter while spraying if you use a window switch
07 GT 5spd Black on Black BBK Equal Length Shorties 4.10s FRPP K springs JLT with canned tune Pypes O/R H Pype Bomb axleback Steeda UDP |
#7 | |
Spray + Rev limiter = Big Problems. Get a window switch if you dont have one.. you shouldnt be touching the rev limier while on spray..
CAI, P&P 75mm Throttle Body and Intake Plenum, Pypes Cat Back Exhaust, FRPP 4:10 Gears. ![]() ![]() GOBAMA |
eventually @ something
He's lying the sti pwned the crap out of him then i rolled up and pwned him even harder
2001 Mustang GT
ok i think i found out the problem it happened again tonight, and i looked under my car and there is oil on the right side and there is some oil on my x-pipe, i think the oil is burning off and that the reason for the smoke, my oil has been leaking a bit but not so much, do you guys think there could be too much pressure building up when my car hits the rev limiter causing it to leak more oil?
2007 Mustang GT/CS
Your tune is causing ur shift points to be messed up.. Retune it. and your driveshaft is ur vibration problem.
![]() 2007 Mustang GT/CS 5spd: Flowmaster hushpower axle back,O/R X pipe,JLT CAI,93 Bama tune..laser interceptor dual jammers, Escort Redline RD. |
Get a stick.
![]() Single 67mm turbo, ported pi heads, edelbrock vic jr. manifold w/HPP plenum, terminator shortblock, return fuel system... Goal 600+ rwhp. |
MM.s Used Car Whore
2011 F150 XLT 4x4 5.0
14.89
yup runnin rich
Threads Similar to: Wtf Is Going On With My Car?
| WTF...car and driver (02 gt) | DeMello | The Clubhouse | 8 | October 26th, 2008 01:37 PM |
| found out wtf was wrong with my car | DeMello | The Clubhouse | 110 | September 12th, 2008 02:37 PM |
| wtf is wrong with my car? | DeMello | 99-04 | 37 | August 1st, 2008 04:15 PM |
| jademetals car...PART 2! wtf... | 94v6blkndred | V6 Mustangs | 17 | March 24th, 2008 11:23 PM |
| WTF car leans one side | joe 5.0 | 5.0 Mustangs | 7 | September 1st, 2007 09:11 PM |
