LinkBack (8) | Thread Tools |
#1
2003 GT
A/C delete not needed!!!
The A/C delete dumb pulley has always bothered me. The plastic pulley just didn't look right to me under there. I'm sure it would stand the test of time but it still just bothered me everytime I opened my hood. Someone on another site had posted how they had bypassed their A/C delete so I decided to try it:
Before ![]() After ![]() The Offending Pulleys ![]() What I used to do the mod ![]() Basically, you use a 6 rib V6 pulley and a 70.5 inch long belt. I bought the 6 rib V6 pulley at my local Autozone and the belt I had bought a while back from Summit but never had gotten around to doing the mod. I'm sure any Autozone/O'Reilly's will have it. It was fairly easy. Take your rachet and connect it to the square in the idler arm. Pull it to your right and pull off the stock belt. Unscrew the idler from the cover. Flip the idler around and you'll see the bolt that holds down the pulley. Unscrew it and take off the pulley. Take a 5/8" or 3/4" thin washer and slip it over the post where the pulley came off. Install the V6 pulley and screw it back on. Make sure that the washer you use doesn't touch the outer steel ring in the bearing. When you tighten it up it'll clamp down on the washer and the V6 pulley won't spin. Tighten down the pulley and check to make sure the pulley spins freely. Take another thin washer(I used another 5/8" one since that was all I had laying around. You may want to take the bolt that bolts the idler to the cover to get the correct sized washer. Just make sure it is a thin one) and use it to space the idler arm out from the cover or else the V6 pulley will rub on the cover. Run the belt the way it is in the after picture(Or look below for a front view). The easiest way is to start with the belt around the idler and start threading it from there. You'll probably get to the crank pulley and not have enough slack to get it around. Take your rachet and put it back in the square hole in the idler and pull the idler to your right while simultaneously wrapping the belt on the crank pulley. Once you have it on just make sure everything lines up and that the idler bolt is tight. Start her up and make sure the belt doesn't come off by revving it to red line a few times. After that you can remove all the other pulleys if you want or you can leave them on. I took mine off and it really uncluttered that part of the engine. I didn't really notice any power boost, per se, but the engine seemed a little more peppy and throttle response was a little more crisp. I'm sure there was some sort of HP gain through less parasitic loss but not really noticeable SOP. Front view of belt routing ![]() John
SOLD - '03 GT, Max Moto Max Grip Box, Wilwood SL 6 front/DL4 rear Big Brake Kit, Corbeau Seats, MGW Short Shifter, MAC Long Tube Headers/Prochamber mid/ Flowmaster 40, FRPP 4.10, TrickFlow Diff Cover/75mm TB/Plenum, Eaton Posi, Moser 31 spl Axles Last edited by Novanutcase; November 29th, 2008 at 01:12 AM. |
wow, that looks great, nice write up
![]() 2000 kenne bell GT (440HP-432TQ) Tuned by Joe at http://www.tricktuners.com dyno vid:http://youtu.be/lr3xpxw2_v8 2011 escape MUSTANG TAT CREW |
2000 GT
I like the write up and pics! very nice. I might try this out some time. What was the size belt you had before and after? Cause i have a little different supercharger setup, so would need the belt difference of my size. And an 8 ribbed pulley for tensioner. Mine is a little out of place (was actually not lined up) and still is but i was able to grind it down to make it so it wouldnt chew up belts (lined up but barely).
I see the after belt was 70.5 inch, what was the before?
2000 Black convertible GT: KB 15psi, and other goodies... ![]() 1971 Datsun 240 z: Header and rebuilt motor. (The DD) |
#4 | |
2003 GT
How do you have your pulley setup now? Is it all 8 rib or just the one on the blower? If so what rib# belt are you running? John
SOLD - '03 GT, Max Moto Max Grip Box, Wilwood SL 6 front/DL4 rear Big Brake Kit, Corbeau Seats, MGW Short Shifter, MAC Long Tube Headers/Prochamber mid/ Flowmaster 40, FRPP 4.10, TrickFlow Diff Cover/75mm TB/Plenum, Eaton Posi, Moser 31 spl Axles Last edited by Novanutcase; November 29th, 2008 at 01:02 PM. |
2000 GT
8 rib on all pulleys. And i run a 108.5 belt. I havent had a stock belt in a long ass time so no idea what the size is.
What is with the ribs on the tensioner? Just to keep it from jumping too much since there are less pulleys to keep it on track?
#6 | |
2003 GT
Do they make an 8 rib idler wheel that is the same width as the stock one? John
SOLD - '03 GT, Max Moto Max Grip Box, Wilwood SL 6 front/DL4 rear Big Brake Kit, Corbeau Seats, MGW Short Shifter, MAC Long Tube Headers/Prochamber mid/ Flowmaster 40, FRPP 4.10, TrickFlow Diff Cover/75mm TB/Plenum, Eaton Posi, Moser 31 spl Axles Last edited by Novanutcase; November 29th, 2008 at 09:43 PM. |
2000 GT
I have no idea, thats the downside for an 8 rib setup i guess!
1997 Mustang Cobra
1/8 - 8.89@86mph
![]() iTrader: 1 reviews
NICE write up!
![]() Modifications and pics in my Garage... Reps Appreciated!
2003 GT
Might want to check out March?
John
SOLD - '03 GT, Max Moto Max Grip Box, Wilwood SL 6 front/DL4 rear Big Brake Kit, Corbeau Seats, MGW Short Shifter, MAC Long Tube Headers/Prochamber mid/ Flowmaster 40, FRPP 4.10, TrickFlow Diff Cover/75mm TB/Plenum, Eaton Posi, Moser 31 spl Axles |
2003 GT
Thanks! I was cruising around today and the car felt.....goosier(Is that a word!
![]() ). Just really peppy. I could of sworn that it added a few HP's but don't quote me on it!![]() I noticed that UPR has a "Short Belt Kit" that does the same thing for $149.00! This cost me $40 tops! They are supposed to be coming out with a billet idler for just this type of conversion but only have it for 87-93. I can't wait to see what it looks like. If it's cool I just may swap out the V6 one.John
2001 Bullitt
how long did it take you to do?
how much was the idler? i might do this since i never use the A/C
![]() MM NEW EDGE COBRA CREW #2 |
#12 | |
1997 Mustang Cobra
1/8 - 8.89@86mph
2003 GT
You use your same idler but you just take off the smooth pulley and use the V6 6 groove pulley. It may work with a smooth pulley but the way the belt wraps the ribbed side will be pulling around a smooth face pulley. I used the ribbed one just to make sure it doesn't slip off since the ribbed one has little side skirts to keep the belt from wandering.
Just make sure you use a 5/8"(or 3/4" depending on how thick the pulley post is) THIN washer. If you use a normal washer it may push the pulley out to far and it will rub against the timing cover. You'll need to get the same thin washer but with a smaller hole circumference the same as the bolt that you use to bolt in the idler to the cover. I used a 5/8" because that's all I had laying around since I was a bonehead and didn't think about spacing the idler. John
thats some good info yo!! this should be a sticky in the how to section
TT Bullitt
![]() iTrader: 2 reviews
It didn't look like you mentioned it anywhere in your post. Did you rip out the entire ac system or are you just bypassing it for now? I'm considering doing an a/c delete as people claim close to an 80 lb weight loss (removing everything, behind the dash, etc.)
since this is a pullie thread i got a pullie question...
can you put underdrive pullies on with a supercharger?
2000 GT
no. It reduces the boost (cause of the crank pulley size).
thanks
#19 | |
2003 GT
John
2001 Bullitt
all in all this took me and one friend about twenty minutes to do
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/99336-c-delete-not-needed.html
| A/C Bypass - Crownvic.net | This thread | Refback | November 8th, 2011 07:46 PM | |
| A/C Bypass - Crownvic.net | This thread | Refback | November 2nd, 2011 03:02 PM | |
| A/C Bypass - Crownvic.net | This thread | Refback | August 28th, 2011 01:53 PM | |
| A/C Bypass - Crownvic.net | This thread | Refback | May 29th, 2011 08:16 PM | |
| A/C Bypass - Crownvic.net | This thread | Refback | March 20th, 2011 04:19 PM | |
| A/C Bypass - Crownvic.net | This thread | Refback | March 2nd, 2011 08:15 PM | |
| A/C Bypass - Crownvic.net | This thread | Refback | March 2nd, 2011 06:07 PM | |
| A/C delete not needed!!! | This thread | Refback | November 30th, 2008 03:51 PM | |
Threads Similar to: A/C delete not needed!!!
| AC Delete and Smog Pump Delete | triplethreatt77 | 5.0 Mustangs | 14 | December 24th, 2007 07:09 AM |
| Little Help Needed | GTsetGO | The Clubhouse | 3 | December 13th, 2007 07:52 PM |
| what all is needed?? | Iownastang | 5.0 Mustangs | 6 | October 24th, 2007 02:44 AM |
| Help Needed | XxMUSTANGxX | V6 Mustangs | 34 | February 19th, 2007 11:13 PM |
| What's needed?? | 2ndChildhood | 94-95 | 3 | December 4th, 2006 12:49 AM |
