Car wont start
Old December 2nd, 2008, 02:12 AM   #1
adam654's Avatar
03 GT Centennial Edition
adam654 is on a distinguished road
Angry
Car wont start
Okay last week before thanksgiving break my car decided to let me down and wouldnt start . My dad and i changed the pump and filter and it ran good to my job but when i was ready to leave it wouldnt start up again just kept turnin over. It isnt any fuses and its not the thefe thing either. Does any out there have any insight on this!!!!!!!!!!!!!
02 GT
Old December 2nd, 2008, 02:15 AM   #2
2000 GT
RyanGT is a jewel in the roughRyanGT is a jewel in the roughRyanGT is a jewel in the rough
The battery probably. Get it tested. They tend to go bad in the cold weather when they are old. Im guessing you jumped the car after you put pump and filter in?
2000 Black convertible GT: KB 15psi, and other goodies...
1971 Datsun 240 z: Header and rebuilt motor. (The DD)
Old December 2nd, 2008, 02:17 AM   #3
Whatever it originally would be
Seabee's Avatar
05 Saleen #824
Fast as fuck
Seabee is a splendid one to beholdSeabee is a splendid one to beholdSeabee is a splendid one to beholdSeabee is a splendid one to beholdSeabee is a splendid one to beholdSeabee is a splendid one to beholdSeabee is a splendid one to beholdSeabee is a splendid one to behold
Send a message via AIM to Seabee
battery. I had the same problem. For a day after i changed out the pump and filter it ran. Parked it at night, went to start it up to put my top back up, didnt start. got a new battery, started right up and havent had a problem since.
MILITARY CREW
ANTI ILLEGALS CREW FOUNDER
Old December 2nd, 2008, 03:12 AM   #4
moosenuk17's Avatar
2000 ford mustang GT
moosenuk17 is a jewel in the roughmoosenuk17 is a jewel in the roughmoosenuk17 is a jewel in the rough
Send a message via AIM to moosenuk17 Send a message via MSN to moosenuk17 Send a message via Yahoo to moosenuk17
battery,
2000 kenne bell GT (440HP-432TQ)
Tuned by Joe at http://www.tricktuners.com
dyno vid:http://youtu.be/lr3xpxw2_v8
2011 escape
MUSTANG TAT CREW
Old December 2nd, 2008, 03:22 AM   #5
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
check the inertia switch and make sure the frps is plugged in.
Old December 4th, 2008, 01:11 AM   #6
adam654's Avatar
it cant be the battery cause it turns over just wont start
02 GT
Old December 4th, 2008, 01:19 AM   #7
2000 GT
It could be. You just replaced the fuel side and it didnt make it better. It could get enough juice to turn, but not enough to crank. Cold weather generally makes an old battery show it. Its a free test.
Also i would check the intertia switch as 2k said. Its in trunk driver side, behind the lining (pretty much behind the tail light). Will have a red button. Should be pushed in.
Old December 4th, 2008, 01:37 AM   #8
Seabee's Avatar
05 Saleen #824
Fast as fuck
^ yea i had the problem, pushed the switch, nope didnt work. Fuel pump was bad, and battery. Get the battery tested if you press the switch and it doesnt work.
MILITARY CREW
Old December 4th, 2008, 10:28 AM   #9
limited's Avatar
99 limited edition vert
limited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of light
spend the $50 and get a fuel pressure guage,and see if your getting fuel pressure,since it did not start and it ran for awhile after pump change it sounds like a bad fuel pump relay or connection. don't just keep throwing parts at it(seen several of your threads)
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1M
Old December 4th, 2008, 12:10 PM   #10
SteviGX's Avatar
13.538@101.72 before cams&slicks&gears
SteviGX will become famous soon enoughSteviGX will become famous soon enough
Send a message via AIM to SteviGX
yeah it can. Thats what happens with a dying battery that doens't have the reserve capacity to start the car.
Mineral Gray Club Member #2
Just your average 22 year old dumbass
If you didn't build your car, and your bragging about it, STFU
Old December 4th, 2008, 12:45 PM   #11
2000 GT
A ghetto way to check fuel rail pressure is leave it on cycle and hit the valve on the fuel rail. Just make sure you are ready for it because it will spray you in the eyes.... So stand back and low.
Old December 4th, 2008, 01:35 PM   #12
mrbigjeep's Avatar
04 mustang gt
7.21 @ 98
mrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to behold
x2...may not have enough to start the car.
cams + 150 shot
Old December 4th, 2008, 01:38 PM   #13
ColdSteel's Avatar
97 Mustang GT
ColdSteel will become famous soon enough
Send a message via AIM to ColdSteel
holy crap. i JUST did this lol
for the record, walmart battery FTL. it puts out like 11.3v, enough to turn it over but not enough to start the car. battery is 2 months old too, and they wont take it back even though it doesn't meet OEM specs.
try the battery thing bro, i did the exact same thing as you, tossing money at it until it works. im out 300+ bucks now. do yourself a favor and go get a motorcraft battery from a dealer, or a high end dry cell or something. dont skimp when it comes to parts.
or you can use starting fluid like i was doing thats always a good idea!!!!
97' GT
98' DSG Cobra
Old December 4th, 2008, 03:55 PM   #14
limited's Avatar
if you think it is the battery,jump start it and see if it starts.if it does buy a battery, if not, look elsewhere
Old December 4th, 2008, 04:00 PM   #15
adam654's Avatar
we jumped it but it still wouldnt start
02 GT
Old December 4th, 2008, 04:01 PM   #16
adam654's Avatar
lol yea my stang has had some problems in its day
02 GT
Old December 4th, 2008, 04:30 PM   #17
XPLICITSTANG's Avatar
1998 MUSTANG GT 4.6
XPLICITSTANG is on a distinguished road
Send a message via Skype™ to XPLICITSTANG
sounds like the starter man you should try to turn your car on and tell your dad to get under the car and hit the starter a couple of times and it should start, that happen to mine and is fine now
Old December 4th, 2008, 04:35 PM   #18
zinc02GT's Avatar
2011 Mustang GT
12.1 @ 116
zinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud of
I'm gonna go out on a limb and say the alternator is draining your battery because the alternator IS NOT WORKING thus creating the battery to die completely after a drive.
Dunno. Try the battery with a multimeter. See if it's putting out 12V like it should and see how it's handling.
Mods in garage. Built suspension and gears since posted times.
Old December 4th, 2008, 04:36 PM   #19
330CubeGt's Avatar
1997 SVT COBRA
1996 Mustang V6
330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light
iTrader: 14 reviews
So you have Fuel Pressure.And your Battery, You say is "good".
Are you getting Any Spark?
-04 IRS - Magnaflow - Wheel Replica - Autometer - FTBR - FRPP - SCT - Brembo - PRO 5.0 - BOI-
Old December 4th, 2008, 04:47 PM   #20
SteviGX's Avatar
That could be true too. I'd check that out.
Threads Similar to: Car wont start
car wont start Jucostud 2005 - 2010 14 September 20th, 2008 08:10 PM
car wont start 1BADSTANG 5.0 Mustangs 12 January 14th, 2008 01:01 AM
car wont start 2007calispecial Modular Mustangs 4 May 18th, 2007 09:05 AM
need help...car wont start orlyr21 V6 Mustangs 8 January 13th, 2007 08:17 PM
Need Some Help - Car Wont Start ANoXiA 2005 - 2010 6 December 23rd, 2006 06:07 PM
