95 240sx problems
Go Back   Forums at Modded Mustangs > Mustang Forums > All Other Vehicles
Old December 19th, 2008, 09:55 PM   #1
StangAddiction is on a distinguished road
Send a message via Yahoo to StangAddiction
95 240sx problems
I've got a couple issues with my 240sx and im kinda hoping someone can sort of guide me to some of the possibile solutions to these problems.
1.) The car drives fine, but when i go over 55-60 mph the front end starts to shake a lot and the steering wheel shakes. It scares me sometimes. So i avoid the highway. I have no idea what it is..
2.) When i go WOT the car pulls until about 4000 rpm, then it's like it pulls HELLA slow from 4000-6000 then when it shifts it starts to pull hard again for a second or two then it pulls hella slow again. The car pulls stronger from 2000-3500 in 3rd than it does from 4000-6000 in 2nd... Any ideas???
3.)The car doesnt always want to idle when i first start it. I have to give it a few light revs and then it idles fine.
"peak hp doesn't mean ish... Its about the area under the curve mannn..."
Old December 20th, 2008, 01:42 AM   #2
SLOW
TheLubracano is on a distinguished road
I suspect the vibration is a wheel balance issue, be it a tire out balance or a wheel out of round. The rest sounds like a couple of different issues layered on top of each other. I would recommend a set of diag dice and some good luck.
Old December 20th, 2008, 03:47 AM   #3
silver_fbody's Avatar
93z, 96gt
silver_fbody will become famous soon enough
Sounds like maybe a fuel/ignition issue. Give the car a tune up. change the plugs/wires oil change, fuel filter change etc..
99 BMW m3
90 BMW 525i
93 Z28
93 Jeep Cherokee
Old December 20th, 2008, 03:14 PM   #4
diag dice?
Old December 20th, 2008, 05:52 PM   #5
mtw002's Avatar
2003 vert gt
12.703@ 107.65 KCIR
mtw002 is on a distinguished road
Send a message via AIM to mtw002 Send a message via MSN to mtw002 Send a message via Yahoo to mtw002
Sr swap and or Rb swap . shaking problem sounds like wheel out of balance.
2003 vert gt 2v teskid build 12.7 @ 107 (SOLD)
1989 mustang lx 92gt short block w/gt40p, explorer intake, 65mm tb, 373 gears, 76mm C&L maf, tubular K-member 14.15 @ 94 (5000' above sea lvl)
Old December 26th, 2008, 01:35 AM   #6
ImpulseCars's Avatar
ImpulseCars is on a distinguished road
about your idle issue, is there any signs of there being a weak electrical supply? dim headlights something like that? if not electrical, maybe give the MAF a look?
Threads Similar to: 95 240sx problems
240sx scxc15 Racer's Corner 9 June 28th, 2008 05:21 PM
1992 240sx El_Cangri All Other Vehicles 30 October 2nd, 2007 01:00 AM
