Focus Transmission Problems
Go Back   Forums at Modded Mustangs > Mustang Forums > All Other Vehicles
Old December 21st, 2008, 05:58 PM   #1
01GTstang's Avatar
2001 MustangGT 2003 Cobra
GT-13.079 @ 104.69 Cobra-12.60 @ 111.11
01GTstang is on a distinguished road
Send a message via AIM to 01GTstang
I'll start by saying this is not my car.... The vehicle is a 2000 Focus 5 speed. The problem with the car is that it will not shift into any gears while the car is running. If it is started in second gear it can be shifted to third but to no other gears, not even back to second. Also if it is started in gear being a forward gear or reverse it will pull the car with the clutch pedal all the way to the floor, it will also sometimes stall if you hold the brake. The car can be put in any gear with the car not running. The slave cylinder has fluid in it and it has no signs of it leaking from the slave cylinder, however it has leaked from somewhere else but the location cannot be found. I'm lost??? Anyone have any ideas what is wrong with this thing?
2001 GT: For Sale, low 13s
2003 COBRA: 12.11@116
Old December 22nd, 2008, 10:23 AM   #2
Authorized Vendor
Matt Cramer's Avatar
Matt Cramer is on a distinguished road
What's the fluid level in the master cylinder? I'd refill the fluid and bleed the clutch system first.
Old December 23rd, 2008, 06:19 PM   #3
01GTstang's Avatar
full. thats what i told him to do i haven't heard anything else beyond that...
Old December 23rd, 2008, 06:40 PM   #4
MM's Resident Ricer
GreenFaleen's Avatar
2006 Scion tC
13.001@113
friction material is gone off the clutch plate he needs a new clutch
NCMM #9
Old January 6th, 2009, 11:23 PM   #5
mmikeclass06's Avatar
another dahm ford
mmikeclass06 is on a distinguished road
clutch. reset the factory clutch quardent (just like you would a mustang) so that it can be driven a little bit more untill new clutch
Threads Similar to: Focus Transmission Problems
problems with transmission energiesource 99-04 17 August 27th, 2008 01:28 PM
Transmission Problems! 05badboy 2005 - 2010 6 February 21st, 2008 11:51 PM
Transmission problems 03 R Code 99-04 2 April 23rd, 2007 04:03 PM
Transmission PROBLEMS. Help White35ThGT 99-04 3 February 21st, 2007 10:47 AM
Having problems with my transmission new 5.0 5.0 Mustangs 6 December 18th, 2006 02:52 PM
