Update on 06 Xterra X
Go Back   Forums at Modded Mustangs > Mustang Forums > All Other Vehicles
Old January 27th, 2009, 12:43 PM   #1
I'm Hella From Nor*Cal
707Stang's Avatar
2008 GTI
14.65 @ 99.83
707Stang is a jewel in the rough707Stang is a jewel in the rough707Stang is a jewel in the rough
So after doing the oil change on my xterra it still makes a horrible clanking noise at 1st start-up. I did a flush, let it drain, filled it back up with 5w-30 Lucas Full Synthetic. Running an STP filter. 53xxx on the clock, 4.0L DOHC, AT, 2WD. And nothing funny came out of the oil, just oil. Any and all help will be greatly appreciated. Thanks guys
The Curse 600 CFM Edelbrock, Hookers, Pertronix billet dizzy, Accel coil, GT40 heads, 5.0 h.o, dynomax exhaust, SSBC, FRPP 9mm wires, tci
Old January 27th, 2009, 05:43 PM   #2
The George Forman of Keepers
JASonic's Avatar
JASonic is a name known to allJASonic is a name known to allJASonic is a name known to allJASonic is a name known to allJASonic is a name known to allJASonic is a name known to all
iTrader: 20 reviews
Send a message via AIM to JASonic
Did you pull a plug and take a look at it to see if it showed signs of anything? Plugs can tell you alot about whats going on.
Old January 27th, 2009, 05:46 PM   #3
707Stang's Avatar
2008 GTI
14.65 @ 99.83
i will tonight it seems almost like its the #2 and #4? the two middle plugs. idk what to look for tho.
Old January 27th, 2009, 06:05 PM   #4
JASonic's Avatar
iTrader: 20 reviews
Check out the pictures and description. IDK, it may help. In the back of my Haines book for my Mustang, it shows similar pictures.
Reading Spark Plugs
Old January 27th, 2009, 06:05 PM   #5
Rico-mofos's Avatar
2008 Bullitt #890
slow
Rico-mofos is a jewel in the roughRico-mofos is a jewel in the roughRico-mofos is a jewel in the rough
Send a message via MSN to Rico-mofos
Are you sure the noise is comming from the engine?
BULLITT CREW #5 LT
GTB mufflers for sale
Old January 27th, 2009, 07:01 PM   #6
707Stang's Avatar
2008 GTI
14.65 @ 99.83
yep sure am!
Old January 28th, 2009, 01:09 PM   #7
707Stang's Avatar
2008 GTI
14.65 @ 99.83
ima pull the plugs tonight and give yall an update.
Old January 28th, 2009, 10:36 PM   #8
JASonic's Avatar
iTrader: 20 reviews
See if you can get a picture.
Old January 29th, 2009, 09:43 AM   #9
04mustang232's Avatar
2004 Mustang V6
14.4@ 96
04mustang232 is just really nice04mustang232 is just really nice04mustang232 is just really nice04mustang232 is just really nice
Send a message via AIM to 04mustang232
spun a bearing?
Is it a rough clanking noise that doesnt go away? Could it be possible engine failure?
Originally Posted by JBIGBOOTSY View Post
I am currently taking a pro dump as we speak. It also feels like about 3" diameter.
Old January 29th, 2009, 10:59 AM   #10
707Stang's Avatar
2008 GTI
14.65 @ 99.83
i wasn't able to pull them last night, but when i start it up i'll try to get a sound clip of it. and pix as well.
Old February 2nd, 2009, 04:24 PM   #11
707Stang's Avatar
2008 GTI
14.65 @ 99.83
So I finally pulled the plugs last night and they were all different colors! The passenger side plugs were all covered in crap! So I ran to kragen got some new plugs. Gapped them and threw them in and no noise at all. My wife took it around the block and she said it ran smoother and felt stronger. Woot!
Threads Similar to: Update on 06 Xterra X
update on my Xterra 707Stang The Clubhouse 5 September 4th, 2008 06:18 PM
2006 xterra 4.0L woes 707Stang The Clubhouse 17 August 18th, 2008 07:05 PM
2006 Xterra V6 Knocking 707Stang All Other Vehicles 4 June 17th, 2008 11:10 AM
xterra 707Stang The Clubhouse 0 June 16th, 2008 01:37 PM
Pro 5.0 shifter update/vid update 07stanggt 2005 - 2010 43 February 29th, 2008 10:17 PM
