2000 focus code p1237.
what could be causeing this problem, first the car wouldnt start but it was dripping fuel under the car. the car sat a few weeks till i changed the timing belt and when i went to start the car, it woldnt start unless i poured some fuel into the intake manifold then i would burn off that fuel then die, i checked the ecu and i got (P1237 Fuel Pump Secondary circuit fault ) what does this mean? any one help please. thanks.....
MM's Coffee Addict
sounds like a fuel pump failure or a relay circuit problem possibly. (have you checked the lines and the connection to the fuel filter as you said there's a fuel leakage?? possibly an unsecured connection or rupture somewhere causing lack of pressure in the system)
what engine do you have? I had a g/f who drove the hell outta her 01 zts with the 2L Zetec and I believe, if memory serves me, she had a recall on the fuel pump sending unit for a lack of pressurization two years ago.
![]() Vortech V2, intercooled @ 10psi. Maximum Motorsports supsension goodie bag car less roll cage. Built '04 IRS. Hodge-podge of Roush/Stalker panels. |
#3 | |
Re: 2000 focus code p1237.
P1237 - Fuel Pump Secondary Circuit Malfunction Note: For LS6/LS8, the FPDM functions are incorporated in the rear electronics module (REM). Also, the REM does not use a FPM circuit. Diagnostic information will be set through SCP. Indicates that the FPDM has detected a fuel pump secondary circuit fault. The FPDM will send a message to the PCM through the FPM circuit, indicating that this failure has been detected. The PCM will set the DTC when the message is received. Open or shorted FP PWR circuit Open FP RTN circuit to FPDM Open or shorted circuit in the fuel pump Locked fuel pump rotor Damaged FPDM For LS6/LS8, circuits associated with the Fuel Pump relay The FPDM sends a 75% duty cycle (750 msec ON, 250 msec OFF) through the FPM circuit to the PCM while the fault is being detected by the FPDM. If the fault is no longer detected, the PCM will return to sending an "all OK" (50% duty cycle) message to the PCM. The PCM will keep P1237 stored in Continuous Memory. The FPDM controls pump speed by supplying a "variable" ground on the RTN circuit.
"Those who forget the past are condemned to repeat it" Rev. Jim Jones |
Threads Similar to: 2000 focus code p1237.
| speaking of the focus | 69fastback | The Clubhouse | 14 | September 30th, 2007 03:08 PM |
| 2000 mustang v6 ODBII code help | knowonecanknow | V6 Mustangs | 8 | July 13th, 2007 12:21 PM |
| Mustang vs. Focus | oklahomastate8 | Drag | 205 | February 9th, 2007 10:21 AM |
| focus code p1237 | bluefocussss | All Other Vehicles | 1 | January 9th, 2007 09:45 PM |
