2004 Mustang Convertible
Which F-ing Engine is this?
I have a 1975 Ford LTD with a v8 engine, and I cant figure out exactly which engine is in it.
it could be: 302 CID Windsor V8 351 CID Cleveland V8 351 CID 351M V8 400 CID Cleveland V8 429 CID 385 V8 460 CID 385 V8 The vin is: 5u63h16678 I cant find a vin lookup for that early year... anyone know how i can find out what this thing is hiding under all that dirt? ( it drives by the way)
![]() 2004 Convertible - SOLD 1999 Coupe - SOLD 1966 Coupe - SOLD 1987 TurboCoupe - Cut in prices! 1970 Coupe - Soon to be 140 Turbo! 1984 El Camino Conquista - moving truck 2011 Convertible V6 Base 2012 Coupe GT Premium 5.0 Baby! |
Anyone?
1988 Notchback
11.19 @ 122mph N/A
Should be a sticker on the passenger side valve cover if it is still there that states what size the engine is.
FluffyTheRhino: One time, the tramp I was fornicating with farted, and I felt it blow my balls backwards. 1988 Notch 347 C4 w/brake 3.90 gear 11.19 @ 122mph 60' 1.67 N/A Full Interiored pump gas car |
look at the water neck where the upper radiator hose goes to the motor.
If it is on the front/bottom of the intake manifold with a 45 or 90 degree turn facing up its a 302 if its on the block its a 351/400m if its on the intake, but on the top side its a big block 429/460 bout the easiest way if you have no clue
Just a truck 5.4 3v: 264hp 317ft lbs rock stock piecing together the next project faster than your first sexual experience |
Priest of the Car Gods
For the record, a 400 is NOT a cleveland. They're both 335-series motors, as is the 351M (which is just a destroked 400).
O o /¯/______________________ |BLAAAAAAAAAAAAAAAAAAAAAAAAARGH!!! \_\ Buy my Bronco, special deal for MM folks |
Cleaned some grease off, the drivers side had the sticker.
351m/400 351 CID Thanks for the help
![]() <br>
If it's a 351M, don't listen to the hype about it being a boat anchor. With a 4 barrel, cleveland heads, and decent exhaust, you WILL pull power out of that motor.
Threads Similar to: Which F-ing Engine is this?
| F***ing OWWW! | zinc02GT | The Clubhouse | 8 | March 15th, 2009 03:59 AM |
| Its F$(@ing Here!!! | spokanemustang | Visual | 55 | March 13th, 2009 06:23 PM |
| This is f-ing with me... | Grabber523 | 2005 - 2010 | 5 | December 25th, 2007 03:51 PM |
| F***ing BS | notsoslow50 | The Clubhouse | 51 | August 31st, 2007 12:28 PM |
