Go Back   Forums at Modded Mustangs > Mustang Forums > All Other Vehicles
Discussing Silverado Problems in the All Other Vehicles Forum. Okay so my dad has a 1984 Silverado that had a 305 in it. Last ...
Old February 18th, 2007, 07:14 PM   #1
MustangMatt96GT's Avatar
13.582@97.59 @ 5800 FT
Silverado Problems
Okay so my dad has a 1984 Silverado that had a 305 in it. Last year we had a shop put in a new 350, and it has not run properly since. I have checked all the wires and made sure they are in the correct cylinder. When using the timing light I cannot see the timing line on the harmonic damper, and that is on cylinder 1 and 6. The reason i did 6 was because its the cylinder that is opposite 1 on the distruber and i thought the timing might be 180 degrees out. The truck is missing and I dont have a clue how to time it. Any help will be apprecatied.
Old February 19th, 2007, 06:38 PM   #2
SALIV8's Avatar
where have u checked for marks? Did u check under the timingchain cover? the gears should have the hash marks. crank and cam gear should be marked.
Old February 19th, 2007, 10:31 PM   #3
I have looked right on the damper, and there is a mark on it and i have even put nail polish on it so its easier to see. But when i have the engine running, and point my timing light at the damper i dont see the mark at all. Thanks and well thats all that is needed to time this engine right?
Old February 19th, 2007, 10:47 PM   #4
SALIV8's Avatar
Yeah- connect to num 1 spark plug wire, disconnect and plug the vacuum advance if you have one, and adjust
Old February 19th, 2007, 11:20 PM   #5
Tryed that! Can't see the mark on the damper no matter what timing I have it at, and so thats why I tryed it on plug 6 thinking it might be 180 degrees out. Any other ideas?
Old February 20th, 2007, 11:33 PM   #6
SALIV8's Avatar
Hey- use white nail polish or somethin ez to see but u did that prolly- Disconnect the vacuum hose- slowly turn the distributer to adjust and if the timing gun s receiving the proper signal from the spark plug wire it should be readable. I can't see why the mark is hidden??? shine the light on the balancer and the pointer. Can u take a pic and pm me or post it???
Old February 21st, 2007, 12:06 AM   #7
Well i really cant get u a picture until maybe thursday, but i have a feeling that the timing light is bad. Its a real old one that my dad bought when he was 15 and now hes 52. So i guess ill try a new timing light, but if that doesnt work ill take a few pictures of how i have it set up and then where I am pointing the light and how I have it marked. And thanks so much for ur help! Hope i can get this figured out. Ever since they installed this engine it has been nothing but trouble!! About 7 oil leaks, all the same one, but each time they said they fixed it and they didnt, and now the transfer case is leaking which it wasn't doing before, and well it doesnt sound good because they dont know how to tune anything!! I mean comon how hard is it to adjust the choke correctly? They are just a bad place to go and I have nothing good to say about them.
Old February 25th, 2007, 07:03 PM   #8
Okay, so its not my timing light. I did finally find the mark on the damper while the engine is running! The only problem is that it is timed way off. When I am timing it on plug 1 it seems to be to the right of the correct timing of 4 degrees by about 20-30 degrees. And when I time it on plug 6 it is about 120-90 degrees out. The other problem, is that the timing mark jumps around, its there one second and then the next its gone. There seems to be no pattern to this. Here are some pictures I took, and just ask any questions about them or anything else.
Old February 25th, 2007, 07:07 PM   #9
srry cant figure out how to resize the pics on my mac. Once i figure out how.
Old February 26th, 2007, 12:28 AM   #10
yeah man i see why u changed it my friends got the same truck 305 are some powerless motors.. stock.. it has a hard time BREAKTORQUING he has to put it in 4low and unlock the hubs to do it.. there bad in 2 wheel drive but 4x4 its crazy...
Threads Similar to: Silverado Problems
84 Silverado MustangMatt96GT All Other Vehicles 15 October 16th, 2007 09:16 PM
85 silverado on 38.5 boggers fs/ft kngkahious Vehicles 3 October 10th, 2007 04:39 PM
85 chevy silverado 4x4 38.5 boggers kngkahious Vehicles 0 October 9th, 2007 09:08 PM
Silverado SS trucks 2000Si All Other Vehicles 2 March 30th, 2007 07:21 AM
cobra vs ss silverado jimmy_cho-cho Street 2 December 21st, 2006 01:57 AM
