I'm Hella From Nor*Cal
2008 GTI
14.65 @ 99.83
who can school me on RX7's
I just got one and need to learn a lot more about it. so if you can "school" me on my 86 n/a 5spd i'd really appreciate it.
The Curse 600 CFM Edelbrock, Hookers, Pertronix billet dizzy, Accel coil, GT40 heads, 5.0 h.o, dynomax exhaust, SSBC, FRPP 9mm wires, tci |
2007 Mustang GT
14.70@97.24
pics?
2008 GTI
14.65 @ 99.83
Noob Slayer
13.82 @ 101.09
cool little cars i like the 3rd gens alot.
rotarys ftl though.
![]() 2003 Black Cobra 10th Anniversary 2.8 Kenne Bell Mammoth LC - Built SRA - T56 - E85 - Spray - Stock Longblock - True Forged Mach 5s 2004 Silver GT 5 speed - SOLD MM Cobra Club Member# 97 |
2008 GTI
14.65 @ 99.83
ftl? why?
Unreliable design. The N/A ones are fine, but once you throw on a turbo or two they become unstable. The spinning rotors have a weak link called apex seals, which under high boost like to break off and destroy lots of stuff.
The single best mod you can do to an N/A RX-7 is installing an "American 8-cylinder performance system". Small block Chevys and LSx blocks usually fit best (Fords can be tricky with the front distributor).
Muscle car? No Import? No Lifted truck? No Lowered truck? No When you have a Ford Ranger packing a turbo 4-cylinder, all you can do is park in the back of the car show and realize that you're one-of-a-kind.
48.47@ 12.58
1990 MUSTANG GT
13.55 @100.64
but those rotary motors sure can turn up the RPM's...
HowStuffWorks "How Rotary Engines Work" MAZDATRIX for Mazda RX7, RX8, Rotary Engine Parts and Accessories Wankel engine - Wikipedia, the free encyclopedia Just some links that might give some insight
![]() 1993 Mustang GT(stock) SOLDhttp://s458.photobucket.com/albums/qq309/mpmarkv/ 1998 Mustang GT(sold):http://s458.photobucket.com/albums/qq309/mpmarkv/1998/ 1991 Mustang GT(sold)http://s458.photobucket.com/albums/q...v/1998/others/ [/SIZE] |
2009 ROTY
they are a blast to drive! but get use to no torque. and premixing your fuel, as a rotary burns oil along with gas. they need to have oil mixed in the gas to lubricate the apex seals. and thats normally your limiting factor to power is apex seals. rotarys require thier own special care, and i really would not suggest them unless its something you really wanna do, and you really want to spend alot of time with your car.
Yeah, until an apex seal takes out your turbo and housing.
![]() These guys can tell you everything you want to know and then some with V8s in RX-7s: http://www.v8rx7forum.com/forum.php
Priest of the Car Gods
This probably isn't the board to ask about rotaries, hahaha. They're plenty reliable, so long as you treat them right.
Don't drive it like a piston engine - going easy on it doesn't mean low rpm, it means letting it spin. Keep up on your oil changes. Rotaries do burn some oil, but you shouldn't have to add any in between 3k swaps. I'd find it really hard to justify running synthetic, as you're not going to get the advantage of longer time between oil changes like you would on a boinger. Premium is totally unncessary. Pre-Renesis rotaries will run fantastic on whatever cheap swill you can feed them. The no-torque thing is a lie - they make torque, just none down low. It's a 1.3L for pete's sake. You have to spin them. Don't go cheap on a clutch. You'll spend a lot of time above 6k on a stock motor, above 8k on a ported one. A cheap clutch will scatter if it's spun too fast, and that's much easier with a rotary. I'd recommend a scatter shield if you really port the motor. Remove the stock exhaust with the cats and seal it away somewhere and use it only for your smog tests. RX-7 cats are EXPENSIVE (there's three, and the big one is over $1k). Here's a couple links that may or may not be helpful: Racing Beat - Mazda Performance Specialists Mazda RX7 | Owners, Parts, Repair, Performance, Mods, Wheels - RX7Club.com CorkSport Mazda Performance - 360-260-CORK http://www.mazdarotary.net/porting.htm - images of the different port types. Now you'll know what the hell people are talking about when they say "Bridgport", "Streetport", etc.
O o /¯/______________________ |BLAAAAAAAAAAAAAAAAAAAAAAAAARGH!!! \_\ Last edited by ReverendDexter; February 11th, 2010 at 10:48 AM. |
2008 GTI
14.65 @ 99.83
damn! rev with the win!!! wow!
#13 | |
Noob Slayer
13.82 @ 101.09
usually when i go to the track twice a week in the summer i see atleast one blow up a week. stock form theyre great. id be afraid to mod one though.
That's only true if a prior owner has removed the oil injection pump (which *is* a halfway common mod).
2009 ROTY
i hang around alot of rotary guys in the mazda club i am in, and from what i have heard, they premix even with the pump active. something about the pump not adding enough due to emissions regulations.
Even on a stock N/A motor? That seems excessive.
2009 ROTY
yuppers. and agree! a couple even have turned thier washer tanks into oil tanks and add another pump to inject more. all seems excessive to me, but i am not too up on rotarys. of course this is all on renisis powered rx8's.
2008 GTI
14.65 @ 99.83
lucky for me i'm not planning on modding this car, just keeping her stock. planning on swapping the oil for a heavier weight. how much oil would i have to add to the gas?
Why would you do that? Remember, this isn't a piston engine, and it has very different care and feeding than a piston engine. I would NOT go to anything other than what's suggested from the factory.
If you're running premix, buy some 2-stroke pre-mix oil, and add per it's instructions. Honestly, though, unless the prior owner has removed the oil injection pump, I wouldn't do premix. AZ's friends are in RX-8s, which use the Renesis motor. While at its core the Renesis is still a 13B, it's a VERY different motor. The Renesis is somehow able to squeeze the same power N/A that the old motor had to have a turbo to make, and requires high octane fuel to do it. The 13Bs also didn't have to pass the same emissions standards that the Renesis does, which is the exact reason specified by AZ as to why his friends add premix. I'd double check with the guys on rx7club before doing it. For the record, I don't think it'll hurt anything, I just don't think it'll help.
#20 | |
2008 GTI
14.65 @ 99.83
Threads Similar to: who can school me on RX7's
| Old School Or New School Mustang "Which Stronger" | garyvang | Racer's Corner | 96 | September 16th, 2008 09:46 AM |
| School | MustangMatt96GT | The Clubhouse | 20 | August 13th, 2008 01:19 AM |
| old school | JASonic | The Clubhouse | 3 | June 22nd, 2008 09:41 AM |
| Old School Meets New School... | 06Stang | Pictures | 42 | May 18th, 2008 10:39 AM |
| New school | DarthStriker | Feedback Forum | 2 | August 27th, 2005 10:39 AM |
