Cones = Yummy!
YELLOW! 2001 GT VERT
46.496
New (Used) 4x4 Service Help?
So I'm buying a 07 sport trac with 56k miles, 4x4 Auto 4.6L 3V.. not sure about the service in the past, it is one owner and in great shape so I'm not worried, but I'm thinking about doing this once I get it home:
1. Change Oil, put in Full Syn 2. Change Diff Fluid (front & rear) Royal Purple Syn 3. Change ATF 4. Change / Flush Coolant 5. put in some lucas fuel / engine treatment Anyone got anything else they can think of, or feel like I'm going overboard on anything here? Thanks
![]() Zombie Killing Club | MM Cleavage Club #7 Specs and Pics in the garage... |
1988 Notchback
11.19 @ 122mph N/A
if your up to it, pull the front hubs and check the bearings and knuckles out, but if it was decently taking care of, it all should still be in good shape. Sounds like you have enough work to do already if your going to do all of that.
FluffyTheRhino: One time, the tramp I was fornicating with farted, and I felt it blow my balls backwards. 1988 Notch 347 C4 w/brake 3.90 gear 11.19 @ 122mph 60' 1.67 N/A Full Interiored pump gas car |
2000 Mustang GT Convert
You mention transfer case?
Plugs of course.... Air filter .... Oh and you need a sweet new air freshner ! |
Getting Laid Is A Bitch
Change the plugs and follow the TSB on the 2 piece plug removal and make sure you have something to extract any that break on you.
Fuel filter. Its got enough miles on it that I'd take it in to have the intake flushed of any carbon build up.
![]() Saleen wheels / Front: 255/45/ Rear: 275/40/ Steeda CAI / 93 Perf. Bama tune Corsa Xtremes, K Springs, Koni STR.Ts, UMI lca relo. Brackets/r lwr ctrl arms J&M adj. panhard bar / Camber plates. |
#5 | |
Cones = Yummy!
46.496
no plus, coil packs, it's a 4.6L 3V! ![]() I did get a nice pina colada air freshner ![]() Thanks ALL!
grease all your pivoting points(control arms, wheel bearings, etc) change all fluids/filters and tune up...... its always a good idea to change the differentil fluid b/c you never know if its been under water/mud, especially in a 4x4
Threads Similar to: New (Used) 4x4 Service Help?
| keep the car or get a 4x4??? | YeloPony | The Clubhouse | 9 | February 18th, 2010 04:39 PM |
| lowering the 4x4??? | xXJayManZXx17 | 99-04 | 29 | March 5th, 2009 10:47 PM |
| I need 4x4 or 4wd | mustang kid 1989 | All Other Vehicles | 14 | January 16th, 2009 12:28 AM |
| 4x4 contest | chefalan23 | 99-04 | 12 | September 29th, 2008 11:30 PM |
| Project NO MORE 4X4 | gt_andy | 99-04 | 12 | March 18th, 2008 08:27 PM |
