d17a1 into a 97 civic ex?
Go Back   Forums at Modded Mustangs > Mustang Forums > All Other Vehicles
Old January 4th, 2011, 08:29 PM   #1
101fng's Avatar
2009 Mustang GT
101fng has much to be proud of101fng has much to be proud of101fng has much to be proud of101fng has much to be proud of101fng has much to be proud of101fng has much to be proud of101fng has much to be proud of101fng has much to be proud of
ok, so my dad totalled his 04 civic lx and he's tight on cash. i offerred to swap his motor into my brother's old 97 EX. my dad doesn't seem to interested but i figure that once i do it, he'll be happy with it until he can get a new car.
so, anybody know what i need to do the swap? both cars are complete except that the 04 is totalled and the 97 doesn't run.
Old January 4th, 2011, 08:45 PM   #2
zinsavage123's Avatar
2001 Mustang GT
12.33@111.23mph
zinsavage123 will become famous soon enough
1st off are they both d-series? both obd-1 or 2? multipoint? My buddy knows alot bout these so give me some more info 1st.
2001 Mustang GT - mods+pics in garage, tuned by matt@performance evolution
1996 Civic DX - my dd
Old January 4th, 2011, 09:35 PM   #3
88TempoGLS's Avatar
2000 Ford Contour SVT
15.2 @ 90mph
88TempoGLS has a spectacular aura about88TempoGLS has a spectacular aura about
Send a message via AIM to 88TempoGLS
Both are OBD 2. OBD 2 was/is required 96+.
was engine is in the 97? what transmissions in both?
2000 CSVT
03 Escape 3L block, 02 Mercury Cougar 2.5 heads, SVT cams untuned. Stock manifolds, short ram intake, MSDS Y pipe, stock exhaust. 195whp/182wtq
1985 Honda 450 Nighthawk
70+MPG average 8200 miles and counting
Old January 4th, 2011, 09:47 PM   #4
MM's DRUNKEN SAILOR
deedub97GT's Avatar
single turbo in the works
as fast as i can push it!
deedub97GT is a splendid one to beholddeedub97GT is a splendid one to beholddeedub97GT is a splendid one to beholddeedub97GT is a splendid one to beholddeedub97GT is a splendid one to beholddeedub97GT is a splendid one to beholddeedub97GT is a splendid one to behold
Send a message via Yahoo to deedub97GT
im pretty sure to swap the d17 into a d16 you need to just take everything from the 04. engine tranny computer wiring harness all for it. even if you dont need to it would be on the safe side. only thing im not sure on is the axle length. if the 04 axles are the right length for the 97 body or if the 97 axles will fit into the 04 tranny. the problem could easily be solved if 1. they are the same tranny and axles. 2. the 97 tranny bolts up to the d17 (which it should since its d-series)
MILITARY CREW GSM3
i love throbbing meat
Old January 4th, 2011, 11:35 PM   #5
RDY4WAR's Avatar
07 Turbo Focus
12.93 @ 105mph
RDY4WAR has much to be proud ofRDY4WAR has much to be proud ofRDY4WAR has much to be proud ofRDY4WAR has much to be proud ofRDY4WAR has much to be proud ofRDY4WAR has much to be proud ofRDY4WAR has much to be proud ofRDY4WAR has much to be proud of
There's quite a few differences to consider.
1) The '97 is a 6th Gen which used a double wishbone style front suspension. The '04 is a 7th Gen which used the McPherson Strut style. Different suspension may mean different axle length.
2) The 7th gen is a bigger, wider frame than the 6th Gen (designed to fit the new K series engines). Motor mounts and such are likely to be different.
3) The '97 used the P2P ECU with V-TEC. The '04 used the L54 ECU since the D17A1 is non-VTEC so you would have to swap the ECU and the entire harness over or "chip" the P2P ECU to not read V-TEC which can be a pain. Especially since the P2P isn't as cooperative as the P28, P72, and P75 ECUs found in the Integras and Si/SiR/GSR/Type-R Hondas.
Honestly, I think you would find it easier to pick up a D16 from a junkyard for cheap and swap it into the '97.
2007 Focus - 230/215, cams/head/manifold swap done, new #s soon ...going E85!
1985 Bronco - 351W & 4WD
1986 Mustang LX - 351W build in the works!
David Michael Smith, 07/25/1956 - 12/08/2011 ...R.I.P dad! I miss you dearly!
Old January 4th, 2011, 11:43 PM   #6
88TempoGLS's Avatar
15.2 @ 90mph
^This.
/thread
2000 CSVT
Old January 5th, 2011, 12:17 AM   #7
RDY4WAR's Avatar
07 Turbo Focus
12.93 @ 105mph
What's wrong with the '97 that it doesn't run? Something that could be fixed for less than $100 in parts or are we talking internal engine failure?
Old January 5th, 2011, 04:50 AM   #8
101fng's Avatar
2009 Mustang GT
i think all that's wrong with the 97 is that the head is cracked. not sure though. i just texted my brother to find out. good call on that though, if that's all it is, i can probably find a head pretty easily.
Old January 5th, 2011, 08:19 AM   #9
RDY4WAR's Avatar
07 Turbo Focus
12.93 @ 105mph
I was at the junkyard near me a couple weeks ago and saw alot of Civic EXs out there with the D16Y8. Grab a head off one for $100, have it cleaned up a bit with a new head gasket for another $100, bolt it on and drive the car.
Now if it was me, I'd go more for performance with it and find a 3rd Gen. Integra with the B18B1 and swap engine, ECU, harness, and everything. I would then hunt down a B18C1 (GSR) or B18C5 (Type-R) head for the bigger cams, titanium valve springs, and VTEC. I would then chip a P75 ECU for the VTEC and done, enjoy 180hp in a 1900lb car. Of course, this is if I couldn't find an Integra GSR or Type-R to begin with and swap everything together but that is rare to find as enthusiasts are on those like a hawk and usually before they ever reach a junkyard.
Threads Similar to: d17a1 into a 97 civic ex?
What should I do to my civic stagecrewgod All Other Vehicles 36 April 10th, 2007 02:32 PM
