Car has been sittng for 20 years....where should i start.
Go Back   Forums at Modded Mustangs > Mustang Forums > All Other Vehicles
Old February 21st, 2011, 07:06 PM   #1
sstang02's Avatar
2002 Mustang Gt
13.4
sstang02 is on a distinguished road
Hey guys i know this isnt a mustang, but i know you guys know your things about cars so i figured i could get some help. My buddy has a 1985 bmw 325e and has been sitting since about 1990. What should i first start..i know im going to need all new fluids, oil, battery, gas, tires, filters, spark plugs and wires. What else should we start with to get this running again. Any info would be greatly appreciated. Thanks
2002 Mustang Gt
Comp Cams XE268H, Accufab Throttle Body, Accufab Upper Plenium, Steeda UP Pullies, K&N Cold Air Intake, 4:10 Gears, HHR Drag Launch Springs, BBK O/R X Pipe to Magnaflow exhaust, Tuned By: Dyno TuneMP.
~274RWHP 296TQ~
Old February 21st, 2011, 07:15 PM   #2
aka Nature boy
sickfox's Avatar
blk 89/red 91 XJ Limited
I like turtles
sickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant future
belts and hoses
Black Stang Crew Founder #-1
MM+Cleavage Club #15
www.xjor.org
I would drag my dick through a mile of broken glass just to hear her fart through a walkie talkie
Old February 22nd, 2011, 12:24 AM   #3
canada_gt's Avatar
1996 mustang gt
canada_gt is on a distinguished road
crush it and get another one
unless u can find some decent used parts for cheap
Old February 23rd, 2011, 07:21 PM   #4
blackGTstang's Avatar
2006 Mustang GT
blackGTstang will become famous soon enough
I'd agree with belts and hoses and you might wana put new gas in there
2006 GT 5spd - 4500k DDM hids Heads&fogs, llumar ATR tint 30/15, Grey 10in stripes, led strips in footwell, clear corners w/switchback leds and smoked rear sidemarkers, HVAC and steering leds changed from green to cool white!
Old February 23rd, 2011, 10:08 PM   #5
R3dFyre02's Avatar
R3dFyre02 has a spectacular aura aboutR3dFyre02 has a spectacular aura aboutR3dFyre02 has a spectacular aura about
dont forget the airfilter... Mice love to turn them into nests... Tires as well. oil needs swapped I would assume. rings might be frozen.... ok, I quit. your just trying to start.....
02GT - Blown motor
86LX 3.8TBI auto replacement daily driver
How to retrofit HID's
Old February 23rd, 2011, 10:37 PM   #6
2000 gt
mustanginky is just really nicemustanginky is just really nicemustanginky is just really nicemustanginky is just really nicemustanginky is just really nice
ya man i dunno, i'm sure the rings are toasted, the cylinder walls are probably rusty. oil, belts, plugs, etc...
Procharged 2000 5 Speed BAB GT, built motor, blower cams, speedy dyno tune 412 hp, 450 rw tq
HARDCORE CREW
BRIGHT ATLANTIC BLUE CREW #1 MEMBER
Old February 24th, 2011, 03:37 AM   #7
RetroGT2006's Avatar
2006 Mustang GT
RetroGT2006 is on a distinguished road
Send a message via AIM to RetroGT2006
Blow it up.
Daily Driver: 2006 Honda CBR600rr
Weekend Warrior: 2006 Mustang GT
Old February 24th, 2011, 09:15 AM   #8
Moderator
03SonicBoom's Avatar
2003 Grand Cherokee
03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of
I would change everything that's been mentioned and then try to start it. Most likely, it's not going to start.
At that point, you get to troubleshoot what's wrong. Most likely you'll have to tear down the engine and rebuild it.
Old March 3rd, 2011, 11:56 PM   #9
1997 F-250, 1978 F-150
est14.6@96
FordmanT is on a distinguished road
Forget all of that......I've personally started many a car that has sat longer and is older than this is. Drain the gas and fill it with fresh, CHECK the fluids and belts and hoses and intake for damage. DON'T replace shit until you see if it even runs. Throw a charger on the batter on trickle to see if it will take a charge, then throw it on start and try her out. It'll cough and sputter some but should smooth out. Then let it warm up and make sure everything is functioning. Then shut it down and start changing fluids, plugs wires belts hoses etc. Otherwise it'll all be a huge waste of time and money!
4SALE:misc 04 cobra: SVT 4vHeads port/polish/deck @SVT, CenterForce dual friction clutch, 4lb crankpulley, Steeda Foxbody strut tower brace, Accufab Intake tube PM 4 info
Old March 4th, 2011, 01:09 AM   #10
maxgst's Avatar
maxgst has a spectacular aura aboutmaxgst has a spectacular aura aboutmaxgst has a spectacular aura about
take out the spark plugs and spray some wd40 on the cylinders, that will help prevent the rings getting stuck
.............................2000 GT Vert.............................
How To Cut/Remove springs
Old March 4th, 2011, 09:39 AM   #11
Silvestris's Avatar
N/A
Silvestris is on a distinguished road
I could see that possibly causing vapor lock though. I say replace everything rubber, new fluids, plugs, filters, but before any of that make sure it runs and that you're not throwing money into a bigger money pit than a regular car would be. Also, try some Seafoam or some kind of fuel additive to clean the engine out. I personally perfer Amsoil P.I. It'll clean up the injectors and the cylinders.
If parts ain't flyin', You ain't tryin'.
Old March 4th, 2011, 09:47 AM   #12
Bringing Yellow Back
zinc-vert02's Avatar
2002 mustang gt
12.2 at 117
zinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to behold
Send a message via MSN to zinc-vert02
probably going to need breaks and break lines
SOON TO BE 5.4 3V POWERD WITH A ROUSH CHARGER HELPING IT
BAMA Performance Drag Team Member #4
Old March 4th, 2011, 07:46 PM   #13
mrbigjeep's Avatar
04 mustang gt
7.21 @ 98
mrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to behold
i'd junk that turd...run it off a cliff
cams + 150 shot
Threads Similar to: Car has been sittng for 20 years....where should i start.
Rolling start compared to standing start PhillyGT 5.0 Mustangs 23 January 25th, 2012 09:49 PM
multiple cranks to start now no start JFSTANG V6 Mustangs 10 November 14th, 2010 11:57 PM
06 mustang gt smokes on start up and idles bad on start up slick06gt 2005 - 2010 23 September 30th, 2010 04:18 PM
Out Of All The Years Of Cricket The Clubhouse 18 December 21st, 2007 11:59 AM
