I'm going On A Manhunt!
2002 true blue GT
speed of time @ 88mph
my demo derby car build thread!!
alright guys and gals, im building a derby car so i made this thread to show the progress and whatnot. it needs to be done by the end of june. The derby is an 80's and newer derby just so you know. my car is a 1983 Delta 88 that runs great.
here she is, in all of her brown glory ![]() removed the fiberglass front ![]() removed the tail lights ![]() the crappy weather is forcing me to put everything in the back of the car and in the garage. ![]() i have a TON of wires to sort through. ![]() so far most of the interior is gone except the front seats, door panels and carpet. there are 6 bolts holding each seat down and two are directly under the slider and the only way to get to them is to move the power seat all the way foreward. but the battery is shot. i had the charger on it for 5 hours and i turned the key and nothing. so hopefully the battery is the problem, i just hope i didnt pull something off that i shouldnt have. ![]() anybody know where i can find headers that go straight up through the hood? the engine is a 307. if anyone has any questions, just ask!
mac lt's, mac O/R H pipe, spintech super prostreets, JLT RAI, 14"antenna, mach 1 chin spoiler, two 12" kickers.
POWA! 24/7 fukkers
1 @ 1
pssst!
we has new section for build threads, look! (read rules, they are a little bit different) Projects Forum awesome project though!!
2002 true blue GT
honest to god, ive never seen that section as long as ive been on this forum.
2004 Mustang Mach1
That's an awesome project. I have thought about building one too just never have gotten around to it. Good luck man
#5 | |
POWA! 24/7 fukkers
1 @ 1
#6 | |
07 Turbo Focus
12.93 @ 105mph
Actually, I think this thread is probably better suited here in the All Other Vehicles section since it's not a Mustang. I'm pretty sure the Projects section is meant for Mustangs only.
2007 Focus - 230/215, cams/head/manifold swap done, new #s soon ...going E85! 1985 Bronco - 351W & 4WD 1986 Mustang LX - 351W build in the works! David Michael Smith, 07/25/1956 - 12/08/2011 ...R.I.P dad! I miss you dearly! |
2002 true blue GT
small update: yesterday was too cold out, my fingers went numb and i had to quit.
hopefully today i can get the door panels out.
Better than Drugs!
97 Cobra makin' women wet
Decent @ A fast one
triple post/ YAY!!
96 GT-sold 98 GT-05 katrina victim-parted 90 GT-traded 98 GT-traded 98 GT-parted 94 GT/Cobra-sold 95 Cobra Saleened-sold 97 Cobra-knock -sold 99 GT-knock-sold 97 Cobra-sold 96 Cobra-nothing wrong but stock! MM Cobra member 969
2002 true blue GT
1997 F-250, 1978 F-150
est14.6@96
Small block chevy right? Just find some shorty headers that have a middle dump and mount them upside-down and then put some piping on them. Something like this.
4SALE:misc 04 cobra: SVT 4vHeads port/polish/deck @SVT, CenterForce dual friction clutch, 4lb crankpulley, Steeda Foxbody strut tower brace, Accufab Intake tube PM 4 info |
#11 | |
2002 true blue GT
im thinking of getting these. ![]() oldsmobile
2002 true blue GT
well, all the interior is now gone and pulled a bunch of stuff off the engine. but i have two questions for you guys.
1. i want to re-wire the car so that the only wiring is for the battery, ignition, and starter. how would i wire that up? 2. theres alot of smog shit on this thing and im wondering what i should and shouldnt pull off it. ill try to get some more pics up in a couple days here.
est14.6@96
Pull every thing off, emissions wise, the only two vacuum lines you'll need is to the distributor advance and the brake booster, remove and plug everything else. Unless you want your heater controls to work than you'll need that too.
To wire it as such I would probably leave the alternator in the loop too. Run a 4ga wire from the battery + to the starter (large terminal only) then a 8ga wire to the alternator from there. Run a small gauge wire from the battery to a push button then from the push button to the small starter terminal (energizer wire). Run a 4ga ground from the battery to the engine block and a small gauge ground to the body. Run a good sized one from the engine to the frame. Personally I would leave the gauges operational which would change up this process some.
est14.6@96
Oh ya, if thats all you want wired then remove all the rest after that with some pulling and some good sharp dikes! I like knipex
2002 true blue GT
alright, thanks. im not planning on keeping the gauges (theyre gone). im going to start on the emissions crap today. i got alot of the sensors unplugged and removed too.
est14.6@96
cool, let me know if there is anything your not sure about. You can always post up a pic and I can tell ya from those
Moderator
2003 Grand Cherokee
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 0 reviews
I would make a couple redundant grounds. I got taken out in my first derby because my single ground got cut in half.
2002 true blue GT
well i found a shop that will let me use their welder today.
and im on the fence about keeping the alternator or not. now to find some metal for a dash bar..... and FordmanT, you seem to know what your talking about. did you used to run in derbys? and thanks for the help.
2002 true blue GT
alright, im gonna post pics and you guys tell me if it stays or goes...
pic 1 ![]() pic 2 hose on valve cover ![]() pic 3 ![]() pic 4 ![]() pic 5 ![]() pic 6 ![]() pic 7 little round black thing in center of picture ![]() and the car started overheting while at idle? no, its not low on coolant.
07 Turbo Focus
12.93 @ 105mph
I couldn't tell you about the vacuum lines but overheating at idle while full of coolant sounds like a water pump.
Threads Similar to: my demo derby car build thread!!
| build thread | 69fastback | 5.0 Mustangs | 27 | April 8th, 2011 10:16 AM |
| Roller Derby? | eleanor08 | The Clubhouse | 5 | March 7th, 2011 01:57 PM |
| build thread | culookn | Feedback Forum | 3 | January 10th, 2010 11:53 AM |
| Demolition Derby | Countryboy_99 | Circle | 15 | April 12th, 2007 07:09 PM |
