2001 F150 5.4: Intake gasket?
Go Back   Forums at Modded Mustangs > Mustang Forums > All Other Vehicles
Old April 25th, 2011, 02:02 PM   #1
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
I have an '01 F150 5.4, and I started getting the common misfire. I had a friend of mine scan it, and number 8 was the only cylinder misfiring. I went to replace the COP, and the plug, and when I pulled the plug out, I noticed it had what smelled like antifreeze all over it. It had leaked down from the top, because the plug socket was covered, as well, as the top of the plug. The liquid was dark and oily, but didn't seem to actually be motor oil, and smelled like antifreeze. I'm assuming it has just sat down there and became dirty.
I replaced the COP and plug, and it almost immediately started having the same misfire, as I expected it would. I started looking around, and I've found a few small traces of antifreeze near the front of the intake. It doesn't appear to be coming from the radiator hose on that side, although there is a little just aft of where the hose connects to the intake. It's so hard to see anything, that I can't tell exactly where it is coming from, but I assume the intake gasket is leaking, and the water is working it's way down into the COP, and causing my misfires. It's getting pretty bad too. It's really gotten bad over the weekend, and I really don't want to drive it anymore.
I'm just curious if anyone has seen anything similar, and if there's something I should look for before I tear into the top of it to replace the intake gaskets? Something that I may be overlooking? Thanks in advance.
./___ _ ____ ___ \.
( ]]] _ _ O _ _ [[[ )
\_ o _ _____ _ o _/
|___| ......... |___|
Old April 26th, 2011, 12:15 PM   #2
Getting Laid Is A Bitch
Destination S197's Avatar
2007 Mustang GT
13.481 @ 103.65
Destination S197 is just really niceDestination S197 is just really niceDestination S197 is just really niceDestination S197 is just really niceDestination S197 is just really nice
Send a message via AIM to Destination S197
Check the first and last post here.
Ford F150 - 5.4L/2002 - Intake manifold/gasket leak into sparkplug cup. - Ford F150 .net
Sounds like you're on the right track with the intake gasket.
Saleen wheels / Front: 255/45/ Rear: 275/40/ Steeda CAI / 93 Perf. Bama tune
Corsa Xtremes, K Springs, Koni STR.Ts, UMI lca relo. Brackets/r lwr ctrl arms
J&M adj. panhard bar / Camber plates.
Old April 26th, 2011, 04:04 PM   #3
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
Yeah, that's almost got to be what it is. Joy for me. Instead of finishing my car up this weekend, I get to tear my DD apart.
./___ _ ____ ___ \.
\_ o _ _____ _ o _/
Old April 26th, 2011, 04:19 PM   #4
2007 Mustang GT
13.481 @ 103.65
Goodluck with it dude, I know how much it sucks.
Threads Similar to: 2001 F150 5.4: Intake gasket?
intake gasket ? Mlx50man 5.0 Mustangs 9 January 21st, 2009 08:53 PM
intake manifold gasket or head gasket? rasalibre 5.0 Mustangs 5 November 26th, 2008 05:37 PM
F150 Lower Intake Same As Mustangs? 99v6stang V6 Mustangs 6 April 1st, 2008 11:58 AM
2001 F150 Supercrew CNASHGO All Other Vehicles 3 March 17th, 2008 11:09 AM
Intake Gasket 1bad5.0 5.0 Mustangs 4 September 19th, 2007 02:33 PM
