Help please urgent
hey guys im just at work and i went out to start my pontiac grand prix daily driver it would turn over start and immidiatly die. you could also not rev the engine etc and the rpm were litteraly nil i jacked it up and theres a little wire dangling as in a rubber housing with a thin metal cord as if something snapped any ideas guys im a little stuck thanks....??
throttle cable?
MM's Resident Ricer
2006 Scion tC
13.001@113
pics would be nice
definitely throttle cable but the IAC should keep it running at idle your iac is malfunctioning as well it has to be.
prob
if that cable is the sorce of the problem it could be a thorrtle line, MAF sensor would cause to to run crappy to but shouldnt be there, bad fuel filter or fuel pump if its not that cord, turn the key a little and see if you hear the fuel pump run if not hit your gas tank a little and it could work again, could be a realyl beat fuel filter
2003 Mach 1, 5 speed ![]() U.S. Army - 11B "And on the 8th day god created the infantry and all hell stood at attention" |
hmm, if it is a stick did you try keeping it in nuetral before you let go of the clutch after starting it? i know that the throttle cable would result in loss of no gain in rpm's but maybe you had it in first or third and didn't realize it and just didn't pay attention to the clutch and that is what is causing it to die, i know it sounds silly, but it sometimes happens
Sex, Eating, and Driving Fast, the Three Greats in life and I can do all of them without leaving my MGM |
I agree with steamboat 16, the simple stuff is the usually the problem
Threads Similar to: Help please urgent
| URGENT -broke something!!! | Steve O | 99-04 | 27 | October 21st, 2007 06:10 PM |
| Your urgent help is needed!!!!! | 02StangGToWNEr | 99-04 | 25 | September 21st, 2007 08:52 PM |
| HELP ITS URGENT! | jat | 2005 - 2010 | 21 | September 7th, 2007 11:18 PM |
| urgent help! | Black Five 0h | 5.0 Mustangs | 3 | July 24th, 2007 10:01 AM |
| Urgent Question | Timmano | V6 Mustangs | 13 | May 9th, 2007 06:58 PM |
