Intake manifold issue or head issue?
Go Back   Forums at Modded Mustangs > Mustang Forums > All Other Vehicles
Old July 8th, 2011, 11:14 PM   #1
1999 SVT Cobra Saleen
sledgehammer357 is on a distinguished road
My 03 F150 with the 4.6 Triton engine was throwing a misfire code on #3 cylinder. I changed plug and coil. I am losing antifreeze. At first no steam in exhaust, but now there is. Compression is holding at 160 in #3 & #7 cylinders. Pressure checked cooling system and it held. When I pulled the #7 coil, the plug boot was rusted and the spark plug tube was filled with water. The plug smelled like fuel. When I pulled the #3 plug, the plug was wet with what appears to be water. Any ideas on what it could be? Thank you for any help.
Old July 20th, 2011, 01:39 AM   #2
aalv3 is on a distinguished road
getting any bubbles in the coolant when the engine is running? water in the spark plug holes could be as simple rainwater pouring down from the cowl, i've seen it several times, seems to be pretty common as cylinders 3 and 7 are towards the back of the motor an coincidentally right across from eachother.
Old July 20th, 2011, 01:58 AM   #3
also, i'd pull all of the plugs out and see how they look if you're losing coolant and there's no external leak. wouldn't hurt to do a compression test on all cylinders as well. usually when you're burning antifreeze it'll have a steam cleaning effect on the plugs. it's possible that your misfire and your coolant leak are two different problems. don't limit your search to ignition failure either, get a screwdriver and put it to the injector and to your ear, should hear a loud clicking. although if you say the plug smells like raw fuel, i'd rule injection out. good luck!
Threads Similar to: Intake manifold issue or head issue?
New Intake issue GT_s197 2005 - 2010 20 April 10th, 2011 07:14 PM
intake and tb issue zinsavage123 99-04 11 February 27th, 2011 09:05 PM
Head issue on 95GT Canary95GT 94-95 11 February 16th, 2011 06:23 PM
GT40P head/cam swap issue steve86gt 5.0 Mustangs 1 August 2nd, 2010 06:10 PM
head light issue Traidmarx 5.0 Mustangs 7 January 9th, 2009 11:25 AM
