Head porting questions
Go Back   Forums at Modded Mustangs > Mustang Forums > All Other Vehicles
Old October 7th, 2011, 12:21 AM   #1
johnGT's Avatar
1995 Mustang GT vert
johnGT is an unknown quantity at this point
I have a 1975 Camaro LT with a crate 305ci and a TH-350 auto trans. I got the motor for free from a good buddy who wasn't going to use it. It has literally been sitting around for 15~ years. I pulled the car out of a ditch for $500 and have been working on it ever since trying to make it road ready.
Here are some pics:
I have a new carb sitting in my garage and the distributor and wires have been put in place since those pics were taken.
I want this car to be faster than my current mustang but its going to need some help. I want to port the heads and do a cam swap. I'm trying to save some money as well. Can I take the heads off and leave the head gasket that is in there on? Or will I have to replace them? I have worked on smaller motors before, but not a car motor. I want to learn on this motor since it was free so I can be prepared when I go to rebuild my mustang motor. Porting seems pretty straight forward though. Tips? Tricks? questions?
1995 Mustang GT vert: STOCK, AODE (B&M shift kit), 2.73 gears, red leather, 410,000~ miles.
2007 Mustang GT: 4.6, 5-speed, 3.55 gears, black on black. (dads car)
1975 Camaro LT: 305ci, TH-350, weiand intake, 600cfm carb, 3.42 gears.
Old October 7th, 2011, 12:55 AM   #2
08fordgt's Avatar
2008 mustang gt
08fordgt is on a distinguished road
Send a message via Yahoo to 08fordgt
If u want it to b right, Pay somebody to do it. And go buy some cheap heads from the junk yard and practice on them.
Saleen 200 mph guages, JLT cai, steeda spacer, SCT3, bamachips, Steeda UDPs, Hurst, bbk shorties, Pypes O/R X& mufflers, Saleen front anti sway bar, Steeda blue lca, relocation brackets, edlebrock adj. uca, adj. panhard brace and bar,sportlines, cmdp
Old October 12th, 2011, 01:51 AM   #3
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
change the head gaskets. as for porting, its not something you just jump in and do. then there is what you are are planning on doing as well. most chevy factory irons form the 70's have bath tub cumbustion chambers, crappy short side, and not much in favor anywhere else either.
Old October 12th, 2011, 11:06 AM   #4
cleangtvert's Avatar
1991 gt vert
cleangtvert will become famous soon enough
look up mondello performance and look for the tech articals. they also sell a awsome head porting kit. has everything you need. your going to have to do alot to make a 305 run with your mustang though. they just arent a very good platform to make real power with. i'd do a 383 stroker for the most power per dollor in a sbc. i'ts easy to get 400hp/400f#torq out of them.they make a really balanced motor.
Old October 12th, 2011, 01:08 PM   #5
RDY4WAR's Avatar
07 Turbo Focus
12.93 @ 105mph
RDY4WAR has much to be proud ofRDY4WAR has much to be proud ofRDY4WAR has much to be proud ofRDY4WAR has much to be proud ofRDY4WAR has much to be proud ofRDY4WAR has much to be proud ofRDY4WAR has much to be proud ofRDY4WAR has much to be proud of
Keep up the good work, the car looks like it's coming along.
As said before, porting is very involved and something you should research thoroughly before getting into.
I would love to have a 3rd Gen Camaro or Firebird with a 350 small block bored over .040", ~11.5:1 compression, aluminum heads, a good cam, 750 carb, and a 150 shot.
2007 Focus - 230/215, cams/head/manifold swap done, new #s soon ...going E85!
1985 Bronco - 351W & 4WD
1986 Mustang LX - 351W build in the works!
David Michael Smith, 07/25/1956 - 12/08/2011 ...R.I.P dad! I miss you dearly!
Old October 12th, 2011, 03:02 PM   #6
johnGT's Avatar
Thanks for the replies guys. I'm going to get the motor running and broke in before I start any mods. I want to lay down some baseline numbers. I would like to make it an occasional daily driver but it will mainly be a strip car. I'm aware that the 305 isn't the greatest motor...but I got it for free and I'm going to run with it. I've done some research and the heads on it also went on some of the 350s in the 80s. So the heads aren't terrible. They do have a lot of slag and don't look machined well is the main reason I want them ported. The cam is also WEAK. The cam is probably the first mod I'm going to do.
I will probably get some mods done to it, be discouraged about it, sell it, and use that money to beef up my mustang...it just depends on how it treats me. Overall this car is a great learning experience. I'd rather mess up on a chevy than a ford!!!
Old October 12th, 2011, 04:15 PM   #7
RDY4WAR's Avatar
07 Turbo Focus
12.93 @ 105mph
^Can't argue with that logic.
Threads Similar to: Head porting questions
MMR head porting silver03gt 99-04 9 March 14th, 2011 07:26 AM
Head Porting MikeJones 2005 - 2010 10 January 19th, 2011 10:24 PM
head porting MustangSallee 94-95 25 October 24th, 2008 03:12 PM
head porting 5.0 LX 5.0 Mustangs 5 April 22nd, 2008 08:43 PM
Head Porting Questions! 96greenGT 99-04 13 November 14th, 2006 09:21 PM
