How to reattach glass to convertible top? - Forums at Modded Mustangs
post #1 of 13 Old July 8th, 2012, 05:54 PM Thread Starter
I Poop Entirely Way Too Much
The rear glass on my sister VW is separating from the top. Whats the best way to fix it?
Nothing says "were dating" like sticking your dick in her.
03_StangGuy is offline
post #2 of 13 Old July 8th, 2012, 11:26 PM Thread Starter
any ideas?
post #3 of 13 Old July 8th, 2012, 11:29 PM
I <3 Boost
JoshC's Avatar
Send a message via MSN to JoshC
honestly man, once it starts to separate youre better off replacing it. had this issue with my gt and ended up replacing the window cause even if you glue it back together itll start to come apart again.
My 04 Cobra Build <-- pics/info about my car
MM Cobra Club #2.76
JoshC is offline
post #4 of 13 Old July 9th, 2012, 01:47 AM
Cum On Me Bro
sikedsyko's Avatar
Is it a glass window or plastic?
sikedsyko is offline
post #5 of 13 Old July 9th, 2012, 10:49 AM Thread Starter
You saying replace the glass or the whole top? The window is glass. Ive seen a few links online of people gluing it back with good results. Was hopin someone could give me some first hand experience on what works. My sis really doesnt have the money for a new top.
post #6 of 13 Old July 9th, 2012, 11:16 AM
I <3 Boost
JoshC's Avatar
Is the top and back window all one unit or are the multiple pieces to the top?
The tops on mustangs are two pieces. The back window is glued into its own section and then there is the top itself. If her car is the same way you can replace just the window section of the top but if it's all one piece it'll have to be the entire top that needs to be replaced. If you don't have that option you can try cleaning the section of the glass that has come off and glueing it back into place. That usually holds for a month or so but once the window has started to peal away it'll keep wanting to do so.
MM Cobra Club #2.76
JoshC is offline
post #7 of 13 Old July 9th, 2012, 11:19 AM Thread Starter
I believe its all one piece. Cant hurt to try and glue it up.
post #8 of 13 Old July 9th, 2012, 11:48 AM
I <3 Boost
JoshC's Avatar
Deff won't hurt to try just make sure you clean both surfaces really well before hand. I hope that'll do ya some good cause I know how much of a pain these vert tops can be lol
MM Cobra Club #2.76
JoshC is offline
post #9 of 13 Old July 9th, 2012, 01:51 PM Thread Starter
Any tips for cleaning the vinyl? Glass isnt so bad. The work isnt an issue so much as the money. My sister jusut graduated college and doesnt have a job yet. A few hundred for a top are not in the plans.
post #10 of 13 Old July 9th, 2012, 02:17 PM
I <3 Boost
JoshC's Avatar
Vinyl cleaner
MM Cobra Club #2.76
JoshC is offline
post #11 of 13 Old July 9th, 2012, 02:23 PM
I <3 Boost
JoshC's Avatar
Or some sort of top cleaner
MM Cobra Club #2.76
JoshC is offline
post #12 of 13 Old July 9th, 2012, 04:06 PM Thread Starter
Vinyl cleaner
That will removed the old glue?
post #13 of 13 Old July 9th, 2012, 04:26 PM
I <3 Boost
JoshC's Avatar
You're gonna have to scrape it off cause if you use any sort of adhesive remover you'll make it worse.
MM Cobra Club #2.76
JoshC is offline
Human Verification
