*Emergency* on my DD
Go Back   Forums at Modded Mustangs > Mustang Forums > All Other Vehicles
Old August 3rd, 2007, 07:38 PM   #1
noob is on a distinguished road
I was driving home today im my 1997 olds' 88 and had a loss in power basically if you gave it more gas it would just flutter. I could lightly get it to go but it wouldn't really pick up and go and still wanted to cut out. I put it in neutral and gave it some gas and it died out and wouldn't start. after about 15 tries it started and ran the same crappy way i got one more block and pulled off at my aunts who i happen to be by and it died again. I said screw it and got a ride home. But now my dd is out of commission and i need it fixed rather quickly, so i was hoping you guys could give some advice as to what it is. It's seems like it has to be in the fuel system by how it was running. Also when i was outside of the vehicle you could hear a high pitched straining or siren sound from the gas tank area which makes me think fuel pump is going out but im not sure. Any advice as to what i should check and what it could be would be great thanks guys for your help.
"He that is good for making excuses is seldom good for anything else."
"Who is wise? He that learns from every one.
Who is powerful? He that governs his passions.
Who is rich? He that is content.
Who is that? Nobody."
Old August 3rd, 2007, 08:59 PM   #2
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
I'm guessing you need to change the fuel filter. That's a cheap/easy place to start.
./___ _ ____ ___ \.
( ]]] _ _ O _ _ [[[ )
\_ o _ _____ _ o _/
|___| ......... |___|
Old August 3rd, 2007, 09:10 PM   #3
thanks man also some guys on another forum are saying if my fuel tank area was making a high pitched whistling sound that its prolly my fuel pump what's your guys thought on that.
Old August 3rd, 2007, 09:11 PM   #4
I should change that it does seem to be a reasonable place to start thanks man.
Old August 3rd, 2007, 11:39 PM   #5
ujslost's Avatar
fuel pump man. its getting over heated and shutting off
Old August 4th, 2007, 01:34 AM   #6
so what a replacement one and im good??
Old August 4th, 2007, 01:36 AM   #7
ujslost's Avatar
yeah should be
Old August 4th, 2007, 01:37 AM   #8
cool thanks guys i'll prolly change the filter too as soon as im able to find it lol.
Old August 4th, 2007, 02:12 AM   #9
ujslost's Avatar
look on the frame rail under one of the doors
Old August 4th, 2007, 02:24 PM   #10
ok i'll check that out. also i wanted to tell you guys that i went to get my car from my aunts at about 7 am and it was not too warm yet out and it started up and ran just fine so why is it that my fuel pump is getting to hot and shutting off and when it gets hot it starts to sound like a high pitched siren noise?
Old August 4th, 2007, 03:19 PM   #11
ujslost's Avatar
Yep thats what I told you. Its getting hot and shutting off. time for a new one.
Old August 4th, 2007, 06:05 PM   #12
yea thanks for your help man. also what causes fuel pumps to get overheated? is it when they just get old? thanks again.
Old August 4th, 2007, 06:24 PM   #13
ujslost's Avatar
getting old for 1 and if you only fill the tank to like 1/4 tank or there abouts, that will make one heat up quicker. full tanks keep the pump cooler
Old August 4th, 2007, 06:33 PM   #14
oh well is this my fuel filter casing here.
Old August 4th, 2007, 06:38 PM   #15
ujslost's Avatar
I would spray those lines with some PB Blaster before you try loosening them or you could twist the line in 2.
or take it to a quick lube and let them change it thatway if they break a line they have to fix it for you.
thats some pretty bad rust there
Old August 4th, 2007, 06:40 PM   #16
yeah cars a 1997 and I've only had it for maybe 8 months. but that is the filter? and whats that pb blaster run in the store, is it pretty cheap?
Old August 4th, 2007, 06:42 PM   #17
http://www.pbblaster.com/store/morei...m?Product_ID=1
Is that what ur talking about?
Old August 4th, 2007, 07:06 PM   #18
ujslost's Avatar
yeah thats the fuel filter. and thats the pb blaster and it runs around $5
spay it on liberally and let it set for about 30 miins.. and spray again when you get ready to break the line loose.
i suggest you try to tighten the line a little, then loosen a little, then tighten a little, then loosen until it feels like its gonna come off pretty easily that will help break any rust loose that could cause you to just twist the line off.
vise grips might be handy if needed also
Old August 4th, 2007, 11:43 PM   #19
alright i'll try that thanks for helping me out . and for the fuel pump since im not to mechanically inclined yet , it'll be hitting the shop that.
Old August 4th, 2007, 11:48 PM   #20
ujslost's Avatar
nah its easy too.
Threads Similar to: *Emergency* on my DD
question about emergency brake light Paulnhbtx 99-04 2 October 24th, 2007 12:38 PM
Emergency brake cable help Newtgadget 5.0 Mustangs 1 October 16th, 2007 08:57 PM
emergency brake problems usmcsawgunner 5.0 Mustangs 4 June 15th, 2007 01:26 AM
Emergency!!!!..............................Brake flames_blue V6 Mustangs 15 April 12th, 2007 08:28 PM
Annoying emergency brake light HedCR 99-04 10 February 9th, 2007 07:04 PM
