1979 ford mustang
pontiac bonneville 1994
ok so i got this car some dude and he said he was driving it and he went to pass a car on the highway at 65 mph and the engine made a pop and stopped running.he gave me the car the whole top end except the cylinder heads are taken off. any one have any i deas?
my 1979 october 9th fox body mercury capri.i've gone through 4 engines now. ![]() my capri is for sale. contact me at: bluedragon130@hotmail.com |
1979 ford mustang
i thought this was the section my bad. and no it didnt throw a rod im about to tear off the heads and see if it snaped a connecting rod. or a piston pin.
1979 ford mustang
i dont think so ill take alook at it. and i dont know how to move things around do i just start another one in all other vehicles?
I had the same problem out of my 1996 bonneville. but you could have a different culprit. I had a bad ground, yes a bad ground, behind the driver side kick panel. This ground goes to the fuel pump and the power windows. it caused my fuel pump to quit working then start working so fast that my car backfired. then my pump completely quit working. I think that this ground also connects to the ECM.
with this much horsepower it is hard to act maturely. |
1979 ford mustang
i just found out by looking at the door its a 1996 and the crank is bent i just put anew one in and its still doing the same thing.
also check out the cam. They have been know to break, its not very common though.
1979 ford mustang
ok im gonna check the cams see what happens then.
don't you mean cam? there is only one, and you do have the series 2 right?
1979 ford mustang
the cams are fine it must have aftermarket heads on it running dohc. im really confused i just bought a painless wirringkit to see if thats it too.
I am confused too. The 1996 pontiac bonneville had a 3800 series 2 engine. It is a 90 degree v-6. it has one cam in the block, not overhead cams. the bonneville was never offered with DOHC. nor are there any aftermarket heads that will allow a swap to use DOHC, so either your car has an engine swap or you are mistaken.
1979 ford mustang
i took the engine out of the car and i hace it on my truck im going to take it into the dealership and ask them about the numbers if they match the car.
that is a good idea. GM only made 2 DOHC v-6's the 3.4 and the northstar 3.6
1979 ford mustang
the engine is fucked pontiac ppl said the engine is toast and the cams are done and its a 5.7 liter v-6 the engine is all out of ballance and its done it got fried.
Threads Similar to: pontiac bonneville 1994
| Pontiac | scxc15 | Racer's Corner | 24 | December 14th, 2007 01:16 AM |
| 2006 Ford Mustang GT vs. a S/C Pontiac GTO SS | Zak | Videos | 16 | November 6th, 2007 09:26 AM |
| 2007 Pontiac G6 | Bies08 | Drag | 15 | March 7th, 2007 08:10 PM |
