Go Back   Forums at Modded Mustangs > Mustang Forums > All Other Vehicles
Discussing 1998 Chevy Fuel Pump Problems in the All Other Vehicles Forum. i got a 89 chevy k1500 z71 a long time ago the rear end went ...
Old August 17th, 2007, 06:02 PM   #1
mattstang's Avatar
i got a 89 chevy k1500 z71 a long time ago the rear end went out got it fixed fuel pump i changed couldnt get it to start said fuck it took it to a mechanic and the cpi system went out and i got that replaced ran for a while went out on a job then i came back and fuel pump wasnt even cycling thats where im at now has anybody had this problem or replaced their pump and sender with aftermarket pieces like holly aeromotive etc........
Old August 17th, 2007, 07:33 PM   #2
TurboLX's Avatar
1990 Mustang LX Turbo
8.67@165.91 mph
I had the worst times with Holley's fuel systems, there pumps are so $hitty compared to Warlboro
Wiring Diagrams, TSB's, OBD Service Codes and Engine Diagrams Available. PM For Info
Myspace
Small Block Posse
Old August 17th, 2007, 07:48 PM   #3
mattstang's Avatar
Re: 1998 chevy fuel pump problems
edit its a 98 and thanks for the input
Old August 24th, 2007, 01:17 PM   #4
Sorry for the post bump but i wasn't sure if you fixed it yet. All full size GM's from about 95 and up have fuel pump problems. They only last about 80k. The only pumps I trust are delco pumps, all the others seem to fail after a month or two. If you do change the pump again, look at the wiring connector real close. The pins are small and a weak fuel pump draws enough amprage that they melt the plug sometimes. Hope that helps.
Old December 14th, 2007, 12:41 AM   #5
If you want to check the relay for it,swap it with the horn relay and try to honk the horn.
Old December 17th, 2007, 11:10 PM   #6
+1 to everything above.
Also note that on my 96 Tahoe, not only did the pump fail, but I still had pump problems after the new one went in.
As it turns out, there was intermittent connection between the fuel pump, and the plug that powered it. I bent the pins on the pump "down" a little to force them to make contact with their mating terminals on the plug, problem solved.
Good luck!
Threads Similar to: 1998 Chevy Fuel Pump Problems
FS: 1998 Chevy S10. Looks and Runs Great DeathScythe95 Vehicles 4 September 25th, 2007 11:10 PM
1998 chevy monte carlo notsoslow50 All Other Vehicles 2 September 11th, 2007 02:20 PM
Fuel Pump Problems bigbadtalontsi 5.0 Mustangs 5 March 30th, 2007 04:50 PM
1998 Mustang V 6 problems Burner0185 V6 Mustangs 0 October 20th, 2006 04:21 PM
Fuel Pump problems petro68 5.0 Mustangs 5 August 24th, 2006 06:12 PM
