Tire, Alignment, and Wheel Bearing Problems!!!
Go Back   Forums at Modded Mustangs > Mustang Forums > All Other Vehicles
Old August 22nd, 2007, 02:10 PM   #1
yohonson is on a distinguished road
I bought a set of Kumho tires at the end of June. I had an alignment at the same time. When I left the shop, I had a rumble in my tires. I was told that the tires were new and that the quality wasn't as good as other tires and that I would have a slight rumble in them. I went back the other day and had the guy ride with me down the road and he said it sounded like a wheel bearing going bad in my right front. How can a wheel bearing go bad while it sits at the shop? He took my front right off and the inside of the tire is wore. He said the wheel bearing going bad can sometimes cause the alignment to go out. When I turn my tire to the right the rumble isn't as bad. Does anybody have any ideas what could be wrong? I think it is either the tire or the alignment job they did at the end of June.
Old August 22nd, 2007, 03:02 PM   #2
TurboLX's Avatar
1988 Mustang LX Turbo
Its not aligned thats for sure, if it wobbles at certain speeds, then the wheels need to be balanced
get it aligned first before anything else
Old August 29th, 2007, 01:01 PM   #3
Mustang4112002 is on a distinguished road
yea i would get it aligned before anything stay away from sewrs in the street and bumps and stuff that will make your alignment even worse not much worse but still pretty bad.
Old August 29th, 2007, 01:24 PM   #4
TheUNZippee!'s Avatar
There are a number of possibilities to check out here.
Bad wheel bearing as mentioned.
Balance, as mentioned.
However, since by your post it seems that you are saying the car had no issues before getting new tires, my money is on one of two things.
1. You have gotten a bad tire with a broken belt in it. Look for bumps along the sidewall of the tire. Although you can have a broken belt in the tire and not have it visible.
2. They either didn't balance them properly, or they messed something up on your car, be it the alignment, the balancing, or something mechanically. There is no way that from June to now those tires should be wearing unevenly if the car had new tires, and was aligned & balanced properly.
Try going to another tire shop or shop that does alignments, and tell them what you have going on and how you should approach it.
BONER CREW EMPLOYEE - BWAL, CEO
Originally Posted by My Wife
Threads Similar to: Tire, Alignment, and Wheel Bearing Problems!!!
tire and wheel question sonicblue 5.0 Mustangs 22 October 13th, 2007 07:36 AM
wheel bearing help RC02GT 99-04 11 August 12th, 2007 10:54 PM
tire and wheel question noob 99-04 14 June 17th, 2007 02:47 AM
Tire and wheel sizes wagwjjr 99-04 0 March 2nd, 2007 07:02 PM
How To Remove The Hub / Wheel Bearing Assembly 2000v6 V6 Mustangs 0 September 17th, 2006 10:41 PM
