4R70W questions
The trans is out of my 96 T-birb with a 4.6. What happened was the one-way clutch on the reverse drum came apart and locked up, toasting the clutches in the direct drive drum. When the one-way came apart it damaged the reverse drum and sprag. Common problem from what I hear.
My first question is, should i get a new drum with the updated mechanical diode or will an original style with the roller clutch be ok? My other question is, should I spend the money on solid teflon seals for the nose of the output shaft or will the cut style be ok? As far as the rebuild goes, I plan on using Alto and high energy clutches. Maybe doing the J-mod to improve shift quality and replacing the shift sol. TCC, EPC and both servos. I do have bit of a lead foot , no burn outs or anything, but the car is stock and a daily driver. I don't need a bulletproof trans just something that will last another 100k.Thanks in advance for any help. |
Found the info I was looking for. The stock roller clutch on the reverse drum tends to explode on 1-2 shifts above 5000 rpm. Looks like Ill be using the updated one. As for the seals, the new kit came with solid so thats whats going back in.
Threads Similar to: 4R70W questions
| T45 or 4r70w??? | the real shocker | 99-04 | 8 | October 12th, 2007 06:48 PM |
| EFI 351 Questions? | radster87 | 5.0 Mustangs | 7 | July 23rd, 2007 01:39 AM |
| AODE and 4R70W | acg | 96-98 | 7 | February 27th, 2007 01:24 AM |
| More Questions | Rolis | V6 Mustangs | 10 | December 23rd, 2006 01:00 AM |
