START IDLE, RUNS THEN DIES
Go Back   Forums at Modded Mustangs > Mustang Forums > All Other Vehicles
Old October 4th, 2007, 05:42 PM   #1
slownomo is on a distinguished road
Hey guys/gals..
i have a problem that is *(&(%) me up the car is a a 1986 mustang 50 fi [speed density]
here's what happens, hard start-if left to idle for about a min it dies boom! shuts right down and if you try to give it ANY throttle it's like you hit a kill switch ,....but sometimes if you just floor the car it will run at about 3000 rpm but lumpy sounding as if a cam were in it [but it's stock] if you release the throttle it smooths out for a second and will go to 3500 rpm [sort of acts like a backwards gas peddle revs from floored to idle as opposed the the normal way....but then it dies after a few seconds while idling, will run forever but crappy as described but ONLY IF IT'S FLOORED!
codes I have are low voltage to fue pump relay...maf sensor [replaced it] map sensor [replaced it but still have the code after clearing it] tp sensor out of adjustment code [but got that code when I adjusted it]
my guess at this point is a fuel pump but wanted opinions on this
any ideas/?
Old October 4th, 2007, 08:11 PM   #2
Smelly Fists, Socking Cocks
G.T. Rags's Avatar
Millenium Falcon
G.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant future
u'd prolly get a bigger response in the 5.0 section
I would eat the peanuts out of her shit
Car Salesman Club - The Hammer
ModdedMustangs Conspiracy Group: President
Old October 4th, 2007, 11:45 PM   #3
homebrewed's Avatar
'88 LX body '91 GT D/T
8.7 in the 1/8th
homebrewed is on a distinguished road
how bout the injectors themselves? mine did something similiar to that and it was the injectors. tho. thats just one option...
Founder of the I don't like my shit centerd and want it back the way it was dammit! club
www.myspace.com/evoalliance
greatest band alive
Originally Posted by Tony_90fox View Post
I wish there was a :lickmynuts smiley, because i would use it now
:lickmynuts
Old October 5th, 2007, 01:17 AM   #4
ujslost's Avatar
Im confused, you stated Speed density and then said you replaced the MAF???
Anyhow if it is speed density replace the black box that has a vac hose and a wire connector hooked to it. I for get what its called but I wanta say the Bap sensor. Which is sorta a MAF sensor on the speed density cars.
Old October 5th, 2007, 02:05 AM   #5
I know I was only able to see a pic of one speed density car and there was no maf meter/sensor but there is on this one [california?] or canadian? .
I'll clean and test the injectors for some reason I never thought of those as the problem but it makes sense.
Old October 6th, 2007, 07:04 AM   #6
MORE INFO: the car is from CA and it did come stock w/ a maf! freaky huh? and i am thinking more and more like it might be a bad pcm gotta do more testing but christ every sensor and even the dist. was replaced [before i got it]
QUESTION can i swap in a 9al ? it has a maf but is it still a speed density set up? or not?
Old October 6th, 2007, 12:20 PM   #7
homebrewed's Avatar
8.7 in the 1/8th
I should think so. My car was an '88 4cyl and its got a '91 drivetrain and the PCM/harness out of a GT
greatest band alive
:lickmynuts
Threads Similar to: START IDLE, RUNS THEN DIES
loss of power//ruff idle and engine shut down.// no start dj hexadron 99-04 1 July 25th, 2007 01:41 AM
Rough Idle and Almost Dies After Warmed Up Gallie 5.0 Mustangs 10 April 12th, 2007 09:27 PM
runs for 15 mins and dies fuel pump circuit open code jonboy 94-95 0 March 2nd, 2007 10:14 AM
Idle Problems Code 1506, Idle Overspeed Error jagstang96 96-98 3 August 29th, 2006 05:11 AM
Engine surges at start and idle fluctuates 200KMILES V6 Mustangs 2 May 3rd, 2006 06:23 PM
