LinkBack (27) | Thread Tools |
#21
I have the same problem with my 1994 Ranger. The shop has replaced the fuel pump and the computer... $500 later and still happens.
I've swapped the ECC relay for the Fuel Pump relay (same part# and same little diagram on the side). No change. I've checked the inertia switch and its connector several times. Never a problem while I'm driving... only after I park it someplace and come back an hour or as long as a couple days later. It's happened 6 or 7 times in the last few months. Any other ideas? |
#22 |
Never mind. The problem wasn't the relay itself, which tested fine... it was the socket the relay plugs into. It isn't always making a good connection. Couldn't figure out why I had good power on the meter when I checked the socket... but no click when inserting the relay with the IGN powered up. Didn't click until I pushed hard on the relay.
Now my truck starts! It's been sitting dead for 3 weeks while I fought this problem. Thanks to the previous posters for focusing my attention back on the relay! |
#23 |
Look Ma! My First Post!
I have an 88 xlt ranger, it has a low presure and a high pressure pump. The high pressure pump is about $100 and is in th frame rail between tank and injectors... good luck Oh yeah the reset switch is on the trans hump in center if floor
Threads Similar to: 1990 Ford Ranger XLT fuel pump problem
| 1990 5.0 Fuel Pressure Problem | RMBillings | 5.0 Mustangs | 2 | August 4th, 2007 10:50 PM |
| 1990 Ford Ranger Xlt Starting problems. | Thuemen | All Other Vehicles | 3 | April 22nd, 2007 01:44 AM |
| 1994 Ford Ranger Fuel Pump | DCFD1562 | All Other Vehicles | 5 | September 9th, 2006 06:28 PM |
| My 1990 Ford Ranger Transmission | JThug69420 | All Other Vehicles | 1 | July 14th, 2006 03:02 PM |
| 1990 Ranger Fuel Gauge | Stan27 | All Other Vehicles | 8 | June 20th, 2006 07:08 PM |
