Discussing 84 Silverado in the All Other Vehicles Forum. So its been missing really bad when in drive and at idle. So i bumped ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
All Throttle with a Bottle
12.91@105.29 @ 5800 FT
84 Silverado
![]() We expect shit to break, look foward to realizing exactly when it is happening, and than obsess about dropping plenty of cash to rebuild stronger, so we can try to run it hard as hell and break again. We are sick individuals.
MM Ninja / Site Moderator
2001 Mustang 232/CBR600
14+@Slow
yah u wont hurt it bumping it a few degrees. but uve band-aid fixed it. you should really figure out what the misfire is all about. maybe bad plugs/wires or distributor cap.
![]() Modded Autos Join today, All makes all models ̿̿ ̿ ̿̿'̿'\̵͇̿̿\=(•̪●)=/̵͇̿̿/'̿'̿ ̿̿ |
#3 | |
Its been a POS ever since we got it back witht eh motor swap done! Leaks oil everywhere, doesnt run right. And it has new plugs, new wires, and next on the list is cap. So maybe ill get one of those here soon. THis is my DD now so... It does need to be fixed!
#4 | ||
14+@Slow
Well i can only feel the miss at a really low RPM. Doesnt have a tach, but I would think around 1100 or less. It feels fine other than that.
2001 Mustang GT
the speed of smell
could be a vacuum leak. bumping the timing shouldn't hurt it much. sounds like you've retarded it a little. as long as it doesn't have any problems starting you should be alright. just make sure it doesnt run hot. if it starts running hot make sure you put it back to where it was. and you dont have to have a timing light. just rotate the engine till you get to the desired timing mark, probably somwhere around 10 degrees before top dead center, then use an ohm meter or test light and hook it to the wire that goes from the coil to the distributer. now loosten the distributer and move it until the light/ohme meter comes on.
![]() '01 GT P-1SC 383rwhp, 380rwtq 2003 Rubicon (DD) 05 Suzuki SV650S 55mpg moddedmustang's drunk story teller www.myspace.com/jeepwheelerbob |
14+@Slow
also is the EFI or carbed?
No i have a timing light infact 3 of them, but the tards taht swaped motors in it said we didnt need a different damper, but aperantly we do 305 to 350 swap. And it doesnt seem to be a vaccum leak, everything is hooked up and nothing is dry rotted, i have checked that.
Carbed
14+@Slow
spray a can of carb cleaner in the bitch maybe its dirty and sticking, i have a feeling its a distributor issue...... but could also be low compression, or the timing was off, or a head gasket.
#10 | |
And carb is clean!
2001 Mustang GT
the speed of smell
yeah its probably something to do with the carb.. also have you checked the points? or is it electric ignition?
#12 | |
dont know for sure, but it does have a vaccum advance on it. and i dont think is the carb, unless its running lean being it was the carb that came off of the 305 and the 350 needs that much more. I dont htink it was rejetted.
2001 Mustang GT
the speed of smell
i'd check the idle adjustments on the carb and check the gap/contacts on the points..
change the fuel filter then pull the neg battery cable for 15-20 mins to clear the 'puter....I believe the carb is 'puter comtrol..does it have a TBI(carb)...also maybe try so seafoam....check your pvc valve
EVERYONE IS ENTITLED TO MY OPINION ![]() d'mello..your like betty crocker try'ing to fill in for Mr goodwrench*L* 1965 chevelle SS 421 sbc PG trans 3500 stall 4;10 gears,alum d-shaft, brodix heads,roller cam,925 AED carb...grocery getter |
opps sorry read your post wrong thought it was a '94.....no need to pull battery cable...you have an HEI.....is your vaccum advance dist? do you have the factory quadujet on it? if so you can't adjustment idle mixture unless you drill the plugs
one way to check for vac leaks is with a plumbers torch turn it on not lit and trace your vac lines it will rev up if its leaking something in the ignition is my bet cap rotor wires plugs all of them are cheap fixes and a decent place to start
Threads Similar to: 84 Silverado
| 85 silverado on 38.5 boggers fs/ft | kngkahious | Vehicles | 3 | October 10th, 2007 04:39 PM |
| 85 chevy silverado 4x4 38.5 boggers | kngkahious | Vehicles | 0 | October 9th, 2007 09:08 PM |
| Silverado SS trucks | 2000Si | All Other Vehicles | 2 | March 30th, 2007 07:21 AM |
| Silverado Problems | MustangMatt96GT | All Other Vehicles | 9 | February 26th, 2007 12:28 AM |
| cobra vs ss silverado | jimmy_cho-cho | Street | 2 | December 21st, 2006 01:57 AM |
