91 Ranger Please HELP!
Go Back   Forums at Modded Mustangs > Mustang Forums > All Other Vehicles
Old November 9th, 2007, 06:47 PM   #1
40thmustanggt's Avatar
40thmustanggt is on a distinguished road
my problem is the timing belt ive took the crank shaft pulley off and where the timing belt slips on theres like a guard and you cant fit the belt between it and it wont come off how does this work?? someone please help!
Old November 9th, 2007, 06:50 PM   #2
TurboLX's Avatar
1988 Mustang LX Turbo
its a pain in the ass
you either
A. Break the cover off
or
B. remove the crank pulley to get to the bottom bolt
i preffer choice A
Old November 9th, 2007, 07:20 PM   #3
you either
or
i preffer choice A
your talking about the back cover?? if yes then thats metal so can i grind it off?
Old November 9th, 2007, 07:21 PM   #4
well let me change that the back cover is plastic but the part at the bottom i need out of the way is metal.. heres a pic of what im talking about.
Old November 9th, 2007, 07:21 PM   #5
TurboLX's Avatar
no the front cover
Old November 9th, 2007, 07:22 PM   #6
TurboLX's Avatar
There's a bolt behind the cam sprocket
thats what you gotta get to
Old November 9th, 2007, 08:58 PM   #7
steveduvall is on a distinguished road
OMG, dont listen to any one, you have to remove the cog from the crankshaft to do this! Then you put your new belt in place and reinstall the gear! its that simple, there are no shortcuts! it just may require one extra 6 pack!
Old November 9th, 2007, 09:20 PM   #8
TurboLX's Avatar
whoops, thought he meant the front timing belt cover
i cant believe a noob called me out on my own motor
Old November 9th, 2007, 11:24 PM   #9
i tried getting it off we couldnt break it for hell 3 of us tried it.. any easy way to get this thing off?? how did you lock your crankshaft from spining?? we used a 2x4 and tried to hold it but no go..
Old November 10th, 2007, 12:31 AM   #10
TurboLX's Avatar
you gotta use an impact gun
Old November 11th, 2007, 02:40 PM   #11
how do i set the timing back ?? need help with that also.. im going to grind the lip off of the bottom and slide the belt on hope it wont mess anything up...
Old November 11th, 2007, 06:33 PM   #12
theres no way i can get an impact gun where the trucks at.. isnt there another way to do this?? i tried to grind alittle away from the lip to slip the belt in and still no go.. and i can't break the cog loose because it moves.. is there away to hold it in place?? we tried a board but it didnt help someone help me please before i burn this truck
Old November 11th, 2007, 07:38 PM   #13
TurboLX's Avatar
is the timing belt still on?
Old November 11th, 2007, 10:16 PM   #14
no it broke and is off
Threads Similar to: 91 Ranger Please HELP!
Ranger Header DONE! -cold-machine- 2.3 Mustangs 115 November 13th, 2007 07:25 AM
Ranger ignition homebrewed All Other Vehicles 0 October 10th, 2007 12:51 PM
need help 91 ranger 40thmustanggt All Other Vehicles 1 August 15th, 2007 06:06 PM
The Ranger is DEAD! TheTechnical99 All Other Vehicles 5 February 6th, 2007 12:55 PM
1998 Ranger Help Bill All Other Vehicles 1 October 17th, 2006 02:58 PM
