Discussing Rust On Hondas, How Much To Fix? in the All Other Vehicles Forum. There is an 89 CRX si that averages 40 mpg (owner had the 5th gear ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
There is an 89 CRX si that averages 40 mpg (owner had the 5th gear redone in the tranny for optimum gas milage). It's pretty cheap but it has some rust at both wheel wells, both doors and the sunroof (not the roof around it fortunately). I was interested in getting it for a back-and-forth-to-work car. What kinda money would I have to fork out to fix it? I could try to bondo it myself but it might be a little beyond that point, especially the drivers side door and wheel well.
11.47@120.58
bondo-ing rust won't fix it, it's like a cancer you have to remove all of it or it will spread. Usually you cut it out, and replace the damaged areas. Their are some chemicals that are supposed to "convert" rust to some sort of primer and stop it from spreading but I don't know if they really work.
Remember, the rust will continue to spread if left unchecked. Whether you should fix it or not is up to you. If your looking for a throw-away car or something then maybe just spend a few bucks and patch it up. PS - usually you'll have 10x more rust that what appears by first looking at it. |
Pretty much what Joe said. Rust usually forms from the inside out.
Take it to a body shop, have them estimate it. If not, buy the car and drive it until it falls apart. |
1988 lx t-top
fiberglass resin is air tight it will stop rust...no oxgen=no rust
just get the chunks off then glass it bondo is corosive never put it on bare metal you have to primer it first |
1999 Ford Mustang V6
prp-porstore.com free catalog, this stuff works good on the other applications.
#6 | |
2003 Cobra & 2002 GT
Re: rust on hondas, how much to fix?
From cars.com Fuel economy city 35 mpg Fuel economy highway 43 mpg
4 Generations of Real Estate Experience Working For You Broker/Owner Http://www.SnowdonRealty.com |
Threads Similar to: Rust On Hondas, How Much To Fix?
| I Dont Know If Anyone Knows... (Hondas) | TurboLX | The Clubhouse | 27 | November 18th, 2007 07:40 PM |
| Hondas are......? | Santaniello3blkstang | The Clubhouse | 161 | June 22nd, 2007 12:27 PM |
| There's rust, and then there's rust... | Mazlem | 5.0 Mustangs | 1 | December 2nd, 2006 05:09 PM |
| Awesome Hondas | mantis99 | V6 Mustangs | 328 | November 25th, 2006 12:45 AM |
