Discussing 88 Marquis in the All Other Vehicles Forum. I know that the 88 Mustang engines came with forged pistons, but does anyone know ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
88 Marquis |
I wana say some did,but i cannot remember how to tell.
Ill do some digging on it
1990 Mustang LX Turbo
8.67@165.91 mph
forged pistons only came on HO motors
Wiring Diagrams, TSB's, OBD Service Codes and Engine Diagrams Available. PM For Info Myspace Small Block Posse NY |
1998 SVT Cobra
Only the HO motors (which only came in the mustang and the lincolns) have the forged pistons. All of the other "5.0"s are the truck 5.0, which is a different firing order, different fuel injection (bank vs multi-port), non-roller motor. Basically it's the "old" 302 with fuel injection on it.
---------------------------------------------------------- The Sacred Chao says "MU" '96 Bronco XLT '98 Cobra '89 Camry AllTrac |
Oh ok. Thanks guys.
#6 | |
2006 GTO
2006 GTO 6 spd Black on Red SLP Loudmouth I catback SLP Blackwing air filter SLP Predator 93 Diablo Tune Jamesbiz Catch Can The Association of GM Performance Member #3 |
8.67@165.91 mph
a cam from the 5.0 mustang has a 351w cam, thats what carries the 351 firing order making it an HO
82 Mustang Coupe w/a 429
From personal experiance with the late 80's 5.0's, There is a difference between the 5.0 car(T.Bird, Cougar,Grand Marquis,Crown Vic) and the F & E Series Trucks and Vans.
The Car blocks are almost all Roller Cam Blocks, where the Truck and Van 5.0's were not, until sometime into the early 90's if I remember correctly. We bought a T-Bird engine to put in our 89 E150 van and discovered that the cams were different. The van did not have the tapped block for the roller lifter spider(Retainer). Just some more info to try and remember. Hope this is useful! |
Now what models did the HO engine come in ? And how much better was it than normal 5.0s ?
2006 GTO
Well specs wise most HOs in the mustangs were in the 215hp/300tq area versus my non HO Grand Marquis which is at 150hp/270tq.
1998 SVT Cobra
The non-HO 302 uses the old ford small block (289) firing order. The 5.0 uses the 351W firing order, so if you wanted to use the HO cam in a non HO motor, you'd have to change the firing order. Now, I know that would at least involve changing where your plug wires were connected at the distributor, what I'm not sure about is if the cranks would be different. I don't believe that the two firing orders are 180 out, so that would mean that the crank would almost have to be a different design.
#13 | |
2006 GTO
1998 SVT Cobra
well, I think this is a case of just pulling a junkyard motor and dropping it in the Marquis.
Like... oh, I dunno... a fuelie 460 from a E350? ![]() Yeah, I know, not gonna happen. But you could grab a 351 from a bronco, grab the heads/upper intake from an Explorer, buy a new lower intake manifold and cam, and have a hot little junkyard motor for about $2K
#15 | |
2006 GTO
1998 SVT Cobra
Yeah, that would all drop right in, 351 is a little taller, so you might have to "massage" the exhaust into place, but it will bolt right up.
But, that being said, what exactly is it that you were wanting to do with the motor in the first place? Just get more power? If that's the case, you could just swap on those explorer heads, from what I understand, the early-mid 90s Explorer 5.0 is basically the Cobra (i.e. GT40) motor.
#17 | |
2006 GTO
#18 | |
2006 GTO
Would a cam made for the older 289 work? Yes I know I'm reaching for ideas, but I just want to know before I make any final decisions.
#19 | |
1998 SVT Cobra
My understanding is that heads, cam, and intake all interchange between the 289 and 302. The heads should interchange between all four 289/302/302HO and 351, and the intakes should work between 289, 302, and 302HO. Other parts, like the timing set, may interchange as well.
Threads Similar to: 88 Marquis
| Wipers not returning to home position 93 Marquis | OTreborO | All Other Vehicles | 3 | January 30th, 2007 08:29 PM |
