1994 Ford Ranger Fuel Pump
SOMETIMES WHEN YOU TURN THE KEY ON THE FUEL PUMP DOES NOT CUT ON' IVE REPLACED THE FUEL PUMP REGULATOR WHICH IS UNDER THE HOOD IN A FUSE BOX ' ALSO IVE REPLACED THE FUEL PUMP AND I STILL HAVE THE PROBLEM.. ANYONE HAVE ANY SUGGESTIONS... THANKS
11.47@120.58
There is a fuel pump cutoff switch somewhere, not sure where it's at on a Ranger though. It's designed to cutoff fuel in case of an accident, they can (somewhat frequenty) trip for no apparent reason. Find it and try resetting it.
YEA IVE CHECKED THAT FUEL CUT OFF BEFORE. NORMALLY I HAVE TA KEEP TURNING THE ON AND OFF SEVERAL TIMES BEFORE THE PUMP WILL KICK ON ...
11.47@120.58
So the pump does work? Or it doesn't? If it's intermittent, problem may lie in the ignition switch (electrical part under the steering column). Just a guess though, don't go replacing parts wildly until you check it.
YEAH IT DOES HAPPEN INTERMITTENLY
have you checked to make sure the electrical is grounding properly. this can cause an intermitent problem.
Threads Similar to: 1994 Ford Ranger Fuel Pump
| 1990 Ford Ranger XLT fuel pump problem | ScyraxxX | All Other Vehicles | 22 | August 9th, 2007 02:15 PM |
| Ford ranger 1/4 mile... | Casper98GT | Drag | 6 | April 27th, 2007 08:49 AM |
| 1985 Ford Ranger | fordboy4rd | All Other Vehicles | 4 | March 11th, 2007 11:26 PM |
| My 1990 Ford Ranger Transmission | JThug69420 | All Other Vehicles | 1 | July 14th, 2006 03:02 PM |
| My Ford Ranger Gas Gauge | JThug69420 | All Other Vehicles | 2 | July 13th, 2006 06:52 PM |
