Discussing Winter beater fuse question in the All Other Vehicles Forum. Went to a brewery last night and after having a nice dinner and a few ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
1988 Mustang LX coupe
Winter beater fuse questionGot up this morning to check things out and I pull out a 15-amp fuse from the place where it said "heater" (duh) in the fuse box and the little bar in the middle (that is supposed to snap when blown) was intact, but the two thick metal tabs on the outsides had what looked like carbonated bubbles all around it and the plastic that encased the metal tabs had blown out somewhat (separated from the metal). So, I take a 15-amp fuse from another area and put it into the heater section, turn on the van and flip the heater switch and walla, I have heat! That is a good thing, but my question is, what happened to the old fuse? Overheat? Too small of a fuse? Too big of a fuse? or what? This van has an auxillary heater for the back that had a 25-amp fuse in it so it makes me question whether that is what is called for for the main heater? Since I don't have the owner's manual and just picked this van up a few months ago and don't know if the person who owned the van before me was a gomer I am clueless as to if I am using the right size fuse and if so, why does the 15-amp fuse look so weird and what happened with it? Any help will be appreciated. Thanx! (Sorry for the long post).
'88 White 5.0 Coupe - AOD w/shift kit w/stock cam - Typhoon intake, Edelbrock hds (1.90/1.60), Crane 1.7 rollers, 76-mm MAF, 70-mm TB, polished VCs, 4.10 gears. Coming soon...Hi-stall converter, mod VB, XE264HR cam and TMoss ported Explorer intake. |
I Touch Myself Sometimes
91 Sonic Blue Goodness
19.83 @ 12mph
fuse crystallization probably.
![]() MILITARY CREW FOUNDER SCT Custom Tuning, JLT intakes, Aeroforce Interceptor OBDII gauges and PLX widebandsemail joe@tricktuners.com |
Ha Ha, and what is fuse crystallization? (I'm not laughing at you), I am just laughing thinking that "fuse crystallization" sounds like a real scientific problem that might need an experiment done on it to fix (LOL). Please expound as I have never seen this happen on a fuse before.
19.83 @ 12mph
same way a light bulb burns out.
basically put.. the contact points on the fuse get crystallized from heat or other means and no longer can make an electrical connection to each other.
"crystallized from heat", so is this an indication that I am using the wrong sized fuse? or a problem somewhere else?
19.83 @ 12mph
no it just happens sometimes.
just like light bulbs fill go out time to time. it could be the filimint in the fuse itself.. but If that one fuse from 1988 lasted that long I would venture to say that another of the same type won't be a problem
Sounds good, thanks for the reply!
I don't need this to happen to me again anytime soon as winter has just started and I need my heat!!!
19.83 @ 12mph
I hear ya.
Good luck man.. glad it was a simple fix for you.
Okay, this thing does not seem to be over yet. I went to take my son ice skating and got in the van, started her up, turned on the lights, drove off, and attempted to turn on the heater and got nothing.
At a stoplight I got the idea to turn off my headlights for a second and try the heater and presto they came back on, so I turned my lights back on and the heater stayed on (thankfully). What could this be? What is really weird is a few days before this the light that lights up the heater control panel went out and I didn't think anything about that and around the same time I had the passenger headlight go out and I haven't replaced it yet. Do you think there is a connection between the headlights and the heater control panel???? Possible short issue?
19.83 @ 12mph
yea it could be a short.. only one way to track it too..
voltmeter
Okay, I will see what I can do with that info.........thanks again!
Threads Similar to: Winter beater fuse question
| What's Your Winter Beater/Pos Daily Driver? | DanTheMan | The Clubhouse | 39 | December 14th, 2007 02:51 PM |
| Beater car for Cheap | 04DSGV6 | For Sale | 0 | October 20th, 2007 10:33 PM |
| exhaust question about winter | xSxTxAxNxGx | V6 Mustangs | 16 | September 30th, 2007 02:54 PM |
| Looking for money for my Beater to be!! | Onemanzu | The Clubhouse | 12 | August 17th, 2007 05:35 PM |
| My Toyota Beater | 99mustang232 | All Other Vehicles | 11 | June 19th, 2006 04:14 PM |
