clicking noise in non mustang vehicle?
Go Back   Forums at Modded Mustangs > Mustang Forums > All Other Vehicles
Old May 6th, 2008, 08:19 PM   #1
07BlkGT's Avatar
2007 Mustang GT
07BlkGT is on a distinguished road
I know this is not a direct Ford Mustang question but if anyone is willing to help please do. My wife has an 06 Chrysler Pacifica 3.5 liter. After changing the oil I noticed there was still a clicking noise similar to an engine running low in oil. She took it to the Chrysler Dealership today and they told her there were major engine problems and have ordered a new cam and she thinks new valves and springs. If tis is true, got any idea what may have caused this problem? Does it sound like there is a huge problem that will not get better? Still under warranty but only for about another 11,000 miles.
I will find out more tomorrow but anyone willing to throw in some .02 I will be more than thankful
Hurst Crew Member #15
Old May 6th, 2008, 11:33 PM   #2
Regency 2007's Avatar
F-150 FX4
Regency 2007 will become famous soon enough
could be valves.... this is common with Mach1's but it didn't mean anything was wrong with them just loud valve sounds...
Old May 7th, 2008, 05:32 PM   #3
Variety=Spice is on a distinguished road
I think I'd ask to see the head while it was apart and look for any scoring of the cams, cam bearings, lobes, or lifters. I suppose it's possible a spring broke and was rattling around in there. Be thankful you're still under warranty!
Old May 11th, 2008, 01:21 AM   #4
Kobra Killer's Avatar
Kobra Killer is on a distinguished road
Solid lifters require regular adjusting but hydraulics usually do not.
Over time hydraulics can get clogged & start to click.
Clevelands Rule
https://home.comcast.net/~jimmiephil...er_project.htm
Old May 11th, 2008, 05:54 PM   #5
07BlkGT's Avatar
2007 Mustang GT
Here is the scoop guys tell me what you think:
They removed the lf head, intake and valve cover and found a rocker too loose. They then removed the rockers and found " lash adj bad " and " lobe on cam worn " ???? Anyone know what this means and if this problem could happen again? My wife picked it up Sat a.m. so I have not been able to speak with them yet to explain
Thanks for any input
Old May 13th, 2008, 01:46 AM   #6
If all the cam lobes are worn I would suspect a lubrication problem.
If only the lobe with the loose rocker, it probably happend when rocker came loose.
Use locktite or lock nuts on rocker arm fasteners.
Clevelands Rule
Threads Similar to: clicking noise in non mustang vehicle?
Clicking Noise Stang187 V6 Mustangs 6 December 12th, 2007 05:17 PM
Getting a clicking noise when i get on the gas Fox2102 V6 Mustangs 33 October 22nd, 2007 12:18 AM
Clicking .. Tapping Noise ... BlackStang V6 Mustangs 30 April 2nd, 2007 05:05 PM
rubbing and clicking noise Warlord Modular Mustangs 2 January 7th, 2007 01:47 PM
Quick Help (Clicking Noise) scubasteve041186 V6 Mustangs 9 November 2nd, 2006 04:37 PM
