2009 mustang bullitt
2005 explorer windows dont work
Like it says they stopped working
checked all fuses under dash and in engine compartment put new master controller in drivers door and still nothing found no broken wires wife uses touch pad all the time could she lock windows closed with that ben casing tail for a week now thanx tony |
chech ALL the switches...sometimes if switch is bad the rest will not work on some cars
BULLITT CREW #5 LT GTB mufflers for sale
did it
think I might have to wait for rainy day and trade it in |
<--- Ford tech.
All windows dont work? Or just the rears? The rears have problems. Havent had problems with fronts as well, unless all 4 dont work. Then you might have a bad GEM.
91 LX, 5spd. Ex:Toyota/Ford tech Marine Machinery Technician, Department of Defense.
all windows dont work
whats the GEM as I put new master controll in drivers door. |
2012 GT Premium
Do youself a favor. Find a Digital Multi Meter ( or a test light if you must be so crude- just be careful- test lights kill computers if not done with ease) and test the voltage at the switch. You should have one wire that is hot with the key on, one (or more) that is a ground, and several others that go hot when you press a window control up or down. If you don't have power anywhere (my guess), recheck all of your fuses, even if you need to pull each one one at a time. Don't forget, Ford has been known to use a circuit braker on the power window lines on some cars, and if the breaker is bad, you will have no power at all. If this is the case. replace the breaker.
Now I've gone and done it...... |
#7 | |
Ok, try this. Check all fuses, if all ok. Remove the door panel and check power at the switch. If none, you need to go to the GEM. Generic Electronics module. Its powers and controls most of the electronics in the vehicle. I have had to replace a few of them. If you give me the VIN i can run youre vehicle and check all SSM's and TSBs on this condition.
Is it stuck open or closed? This is a long shot, but it happens on Mustangs. If it's stuck open, open the door, hold the button to roll the window up (close it,) and slam the door. If it doesn't work, try again. If it still doesn't work, then I'm sorry. Like I said, it's a long shot!
![]() Current mods:
MM Bullitt Crew Founder and Member #1
Threads Similar to: 2005 explorer windows dont work
| Dont Let Just Anyone Work On Your PC... | ChrisJ | The Clubhouse | 37 | March 29th, 2008 03:28 PM |
| Dont you guys work? | Drtbkercr5 | The Clubhouse | 46 | March 24th, 2008 06:08 PM |
| heres something you dont see everyday at work | Dennis | The Clubhouse | 2 | March 22nd, 2008 10:28 PM |
| I Dont Think It Will Work | gixxerkidd1 | General Tech | 0 | November 18th, 2007 09:09 AM |
| my window dont work | GTblackprodigy | General Tech | 5 | May 24th, 2006 11:43 PM |
