How do you
Go Back   Forums at Modded Mustangs > Mustang Forums > All Other Vehicles
Old May 30th, 2008, 03:58 PM   #1
I'm Hella From Nor*Cal
707Stang's Avatar
2008 GTI
14.65 @ 99.83
707Stang is a jewel in the rough707Stang is a jewel in the rough707Stang is a jewel in the rough
How do you
program the clicker on a 2006 xterra x?
The Curse 600 CFM Edelbrock, Hookers, Pertronix billet dizzy, Accel coil, GT40 heads, 5.0 h.o, dynomax exhaust, SSBC, FRPP 9mm wires, tci
Old May 30th, 2008, 04:01 PM   #2
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
This is very simple and works for most nissan models
1) get in and lock the doors with the power door lock on the drivers door
2)Insert key into the ignition 6 -7 times in 15 seconds
3) Hazard lights should flash
4) put key back into ignition and turn to accesory
5)Press the master door lock( on th edrivers doo arm rest) unlock/lock
6) hit the lock button on the remote
7) Hazards should flash
7a) if yo have a second remote repeat step 5, 6 and 7 at this point for the second remote
8) pull the key out of the ignition and open and close the drivers door ( if you do not open the door and close it fully the process won't work)
9)the remote/'s should be set
Old May 30th, 2008, 04:11 PM   #3
707Stang's Avatar
2008 GTI
14.65 @ 99.83
wiki?
Old May 30th, 2008, 04:12 PM   #4
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
nissian forum
Old May 30th, 2008, 04:51 PM   #5
707Stang's Avatar
2008 GTI
14.65 @ 99.83
sCHWEET THANKS MANE!
Old June 9th, 2008, 10:39 AM   #6
Double-Eight is on a distinguished road
what kind of nissan mode?
Old June 11th, 2008, 02:01 PM   #7
707Stang's Avatar
2008 GTI
14.65 @ 99.83
it's an xterra 06 the instructions did the job perfectly
