LinkBack (2) | Thread Tools |
#61 |
1989 LX Vert - 1993 Notch
Fast
LS(Gen-III) motors have an oil cooler port right next to the oil filter that is
not used on most cars. You just tap into that port very easy. k-member cross member under oil pan unbolts, so pan will come off very easy to tap for oil return.
![]() The last President elected in anger of previous President was ....... Jimmy Carter God Help Us |
#62 |
Genibus Nitito Canus
nice, any pumps in ur turbo system? i think a scavanging pump is the correct name
Red 1996 GT: JLT RAI, Steeda Underdrive pullies, Stewart Waterpump; nothing to brag about Black 2009 45th aniverary edition GT 5 speed: K&N CAI, BBK Twin 62mm Throttle Body, BBK Underdrive Pullies, muffler delete ![]() |
#63 |
Fast
No its high enough to drain properly into pan with gravity.
Thats why I dont like low mount turbos, those scavenge pumps are a headache.
#64 |
how so? other than the potential to lose power to the pumps and burn the turbos up
#65 | |
Fast
ie right pump, check valve to keep from draining back, right size restrictor on oil feed to reduce oil getting to the turbo you can blow out the oil seals on the turbo very easy and have serious smoking issues. It can be done right, but def. adds to the complexity of the whole build and more to go wrong.
#66 |
well GreenFaleen brought up an interesting idea about using the side scoops on the sn95 cars as intakes. might try that out. my dads got some t03's he said he'd give me for my car if i wanted to build a kit. hes a agriculural (sp) mechanic so he has a good idea of what i need to do oiling wise.
#67 | |
Fast
Just stick them in the front corners using flipped BBK headers like I did
![]() The last President elected in anger of previous President was ....... Jimmy Carter God Help Us Last edited by r.barn; November 21st, 2008 at 11:51 AM. |
#68 |
what did u use for an intercooler?
#69 |
Fast
#70 |
that thing is a work of art.
#71 |
nice, u think thier 5.4l tt manifolds would work on a 4.6?
Red 1996 GT: JLT RAI, Steeda Underdrive pullies, Stewart Waterpump; nothing to brag about Black 2009 45th aniverary edition GT 5 speed: K&N CAI, BBK Twin 62mm Throttle Body, BBK Underdrive Pullies, muffler delete ![]() Last edited by HBK_2007; November 21st, 2008 at 07:41 PM. |
#72 |
Fast
Got gauge pod mounted.
Wideband should be here tomorrow. Go pick up hot-side from welder tomorrow. Just need to test fit everything one more time and then off to the coaters.
#74 |
thats a pretty sweet pod setup
#75 |
prettyn sneaky too. i got a kinda odd question tho. does the head liner in the TAhoe end with no edge molding (like how the sides are done) like ford did with ur stangs?
#76 |
Fast
There is no molding between headline and windshield.
Just a small gap that you cant see. Few things done. Everything is welded and up at the coaters, should get back mid next week. Also found some used LS2 - 243 heads for $400 that should be here for this weekend. Boost should love the 1/2 pt compression drop and the bigger runners and intake valve. Gotta love these LS motors when you can pick up "stock" 210cc race heads with 2.00 valves and flow 260+cfm for under $500. Got the A/F gauge mounted and all the wires run.
#77 |
do the LS motors all run the same basic block? just different bore and stroke lengths?
#78 | |
Fast
Gen-IV is same block but with bigger bore for engines like the LS2 and LS7 The truck blocks are iron, while the true LS blocks are aluminum.
#79 |
whats the difference in the heads?
#80 |
Fast
Bigger intake valves, bigger intake runners, bigger exhaust runner
better springs and bigger combustion chamber to lower compression 0.5 for boost. Its the stock head for the C5-Z06 Corvette and later for the CTS-V and GTO.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/all-other-vehicles/94728-aint-ford-turbo-tahoe-project.html
| Hotels In Lake Tahoe 2003 Tahoe Engine Cutting Off Hotels In Lake Tahoe | Peugeot9009 | This thread | Pingback | February 16th, 2009 08:13 AM | |
| coil springs for 2002 chevy silverado | Digg hot tags | This thread | Pingback | November 19th, 2008 04:14 PM | |
Threads Similar to: It aint a Ford ...... Turbo Tahoe project
| Budget Turbo Project | stangfreak | 5.0 Mustangs | 31 | March 3rd, 2009 11:25 PM |
| '98 Tahoe. | Dansby | The Clubhouse | 26 | October 11th, 2008 02:43 AM |
| Turbo 3 Valve Terror Project | AMD692 | 99-04 | 4 | March 30th, 2008 01:13 PM |
| Best FORD project car to get? (non-mustang) | nba1341 | All Other Vehicles | 32 | April 30th, 2007 01:54 PM |
