V6 MIL Eliminators
Go Back   Forums at Modded Mustangs > The Marketplace > Authorized Vendors > American Muscle
Old June 21st, 2009, 04:57 PM   #1
kwyse's Avatar
2000 Mustang 3.8
kwyse is on a distinguished road
V6 MIL Eliminators
I'm converting my 2000 V6 Mustang to true dual with most likely an offroad H pipe. In order for the SES light to be off I'm going to need a MIL eliminator.
My question is because its a V6 don't I only need 1 MIL eliminator? (Originally only one cat.)
So, do you guys sell anything for a V6 offroad midpipe setup? I've only seen the 2 pack of MIL eliminators for the GT's.
Thank you very much and thanks for all the great service in the past!
MGW Short Shifter, FRPP C-Springs, Tokico D-Specs, Cobra RSB, FRPP 3.73's and T-Loc, 18x9/10 FR500
Old June 21st, 2009, 05:35 PM   #2
2000 Mustang v6
winnie51189 will become famous soon enoughwinnie51189 will become famous soon enough
Send a message via AIM to winnie51189
you have two precats followed by two regular cats. You also have 4 o2 sensors, but only need 2 eliminators because the sensors after the cats don't actively measure any gas levels.
Old June 21st, 2009, 05:41 PM   #3
yellowstang6r's Avatar
2001 Mustang V6
never ran it
yellowstang6r will become famous soon enough
Send a message via AIM to yellowstang6r
I am getting LT headers sometime soon. Will i still need MIL eliminators if I have my tuner to turn off the rear O2's? Also, for emissions (visual) would i want to use my front or rear cat to weld back in?
Pretty.............................Slow
Mods: Apparently more than 250 characters
Old June 22nd, 2009, 09:08 AM   #4
2000 Mustang v6
If you have a visual inspection you should probably play it safe and just get the extenders so it atleast looks somewhat stock, although the headers will look far from stock If you are welding cats back in I would just get some high flow cats. I don't think it matters which cats you weld back in but the precats are only half filled if I remember correctly. but your tuner should be able to disable them.
BTW I'm just regurgitating what I've been informed of from my questions but the elders, definitely should chime in, to correct me if I'm wrong.
Old June 22nd, 2009, 12:34 PM   #5
Authorized Vendor
AMNick's Avatar
1993 Mustang GT
AMNick will become famous soon enoughAMNick will become famous soon enough
The GT MIL Eliminator kit works on most newer 3.8 V6's, so 1999-2004 you are pretty much safe and shouldn't run into any problems. The older 3.8's have had mixed results.
AMNick
Ex-Forums Liaison
AmericanMuscle.com
PM AMStanger - AM's New Forums Liaison with all questions and discount inquiries!
Old June 22nd, 2009, 02:41 PM   #6
2000 Mustang v6
by older 3.8l's do you mean the 3.9's or do you actually mean the later 99-04's
Threads Similar to: V6 MIL Eliminators
So you want mil eliminators? Seabee 99-04 4 August 16th, 2008 08:07 PM
MIL eliminators? EscortSportage 5.0 Mustangs 5 June 3rd, 2008 10:08 PM
MIL eliminators joejoe8455 The Clubhouse 83 May 6th, 2008 05:45 PM
Mil Eliminators |TH|BLaCkStAnG 99-04 6 July 18th, 2007 07:50 PM
