SCT tuner problem HELP!! plz
Go Back   Forums at Modded Mustangs > The Marketplace > Authorized Vendors > American Muscle
Old August 30th, 2009, 12:17 PM   #1
2003 mustang v6
rene_79_9@hotmail.com is on a distinguished road
Unhappy
Ok so i purchased a sct tuner X3 from AM (americanmuscle) I did a custom 93+ octane tune and as soon as i started driving it started pinging mildly so they advised me to put copper spark plugs and it got rid most of the ping but i still get a ping ive already tried a preloaded tune 91+ and messed with the timing by -1 and -2 degrees AM sounds like there giving up on me and i cant return the tuner?!! When i put it on my stock tune 0% ping nothing never had my car ping ever! and i put the tune and the pinging starts.
ANy advise???? o yea i know its not my gas for sure and i already seafoamed it so yea WTF sct
Old August 30th, 2009, 12:27 PM   #2
muneris pro ego
Ninjawafers!'s Avatar
97 5.0 Exploder AWD
snow has nuthin on me
Ninjawafers! is a splendid one to beholdNinjawafers! is a splendid one to beholdNinjawafers! is a splendid one to beholdNinjawafers! is a splendid one to beholdNinjawafers! is a splendid one to beholdNinjawafers! is a splendid one to beholdNinjawafers! is a splendid one to behold
Send a message via AIM to Ninjawafers! Send a message via Yahoo to Ninjawafers!
its a canned tune so it wont be perfect for every car. some things will still have to be worked out. if the ping stops once you reload the stock tune, then something is a little off on the custom tunes. do you have widebands?
Buy my M90 Kit and my Gears and T-Loc!
MM ZDC - Alaska Base Commander
MM+ Cleavage Club #24
MM Cares Crew / Military Crew
M2C2 President / USCG - OS2
Old August 30th, 2009, 12:33 PM   #3
2003 mustang v6
widebands? not to sound stupid but i dont know know what you mean
Old August 30th, 2009, 12:54 PM   #4
muneris pro ego
97 5.0 Exploder AWD
wideband is similar to an o2 sensor, but has a wider range that it can sence. with a wideband you can datalog with the X-cal 3 and email it to the tuner who should be able to fix the issue for you.
for now i would recommend not using the custom tunes until you can get the issue worked out with AM
Old August 30th, 2009, 01:16 PM   #5
MM's Database Error
WLJohnson05's Avatar
2004 Mustang V6
322.8 rwhp
WLJohnson05 is a splendid one to beholdWLJohnson05 is a splendid one to beholdWLJohnson05 is a splendid one to beholdWLJohnson05 is a splendid one to beholdWLJohnson05 is a splendid one to beholdWLJohnson05 is a splendid one to beholdWLJohnson05 is a splendid one to beholdWLJohnson05 is a splendid one to behold
iTrader: 8 reviews
moved to american muscles section. get in touch with amnick. he will take care of you
Kenwood Head Unit $155
SCT Mass Air Flow Sensor $200
Old August 30th, 2009, 01:24 PM   #6
muneris pro ego
97 5.0 Exploder AWD
thanks wl... i couldnt remember the name. amnick is very helpful to the members here
Old August 31st, 2009, 12:43 PM   #7
Authorized Vendor
AMNick's Avatar
1993 Mustang GT
AMNick will become famous soon enoughAMNick will become famous soon enough
Hmm...need a little more information on your car. Year, motor, mods, etc. There are a few things that can cause pinging in a tuned car besides bad plugs. Also, what brand gas are you using?
-Nick
AMNick
Ex-Forums Liaison
AmericanMuscle.com
PM AMStanger - AM's New Forums Liaison with all questions and discount inquiries!
Old September 2nd, 2009, 02:54 PM   #8
2003 mustang v6
Its a 2003 v6 3.8 mods:K&N air intake, bbk 65mm throttle body, Pypes off road X-pipe Flowmaster catback. Exxon 93 and Shell always
Old September 5th, 2009, 06:22 PM   #9
2003 mustang v6
AT Exxon its 10% ethanol might that affect it???
Old September 8th, 2009, 12:40 PM   #10
Authorized Vendor
AMNick's Avatar
1993 Mustang GT
Hmm...Exxon and Shell are both excellent fuels to use. I usually recommend Sunoco, Mobile/Exxon, and Shell with tuned vehicles...so you should be good on fuel.
Have you checked and replaced your PCV valve? I would replace that first because it is cheap and easy to do. Also run a bottle of Lucas Oil fuel treatment through your gas tank which will help clean out your system.
If there is still slight pinging after this, give us a call or email sct@americanmuscle.com and we can adjust the timing in the custom tune for you. When you contact us, make sure to note the specific RPM range and engine load/throttle position and we can just remove spark from that targeted range. That way performance is not hurt in the range that you are not experiencing the pinging.
AMNick
Ex-Forums Liaison
AmericanMuscle.com
Old September 9th, 2009, 01:30 AM   #11
carnut59's Avatar
2001 gt
carnut59 is on a distinguished road
everyone has 10% ethanol in their gas.
Old September 15th, 2009, 07:18 PM   #12
2003 mustang v6
hey man i already replaced my pcv valve i still get a ping when my car goes under hard acceleration right around 2k rpm ( the ping is not horrible but noticeable )but if I drive normal going light on the gas and not aggressively I hear no ping at all. I noticed i mainly get it when im accelerating up onto the freeway ramp on 4thgear and in highway speeds.
what should i do now?
I already tried -1 & -2 on the spark both custom and preloaded tune should i try to change the fuel like making richer or leaner?
Thank you
Old September 15th, 2009, 07:32 PM   #13
Authorized Vendor
AMNick's Avatar
1993 Mustang GT
Thank you
Send an email to Dan at sct@americanmuscle.com and tell him what you just said in this post about: "under hard acceleration right around 2k rpm ( the ping is not horrible but noticeable )but if I drive normal going light on the gas and not aggressively I hear no ping at all"
He should be able to adjust the tune accordingly and email it to you.
-Nick
AMNick
Ex-Forums Liaison
AmericanMuscle.com
Threads Similar to: SCT tuner problem HELP!! plz
sct x3 tuner problem AMR91 V6 Mustangs 13 August 23rd, 2009 10:27 PM
need sct tuner/ dyno tuner in baton rouge? BakerFX4 99-04 20 April 1st, 2008 11:13 PM
SCT tuner not working - just got tuner & CAI Odin 2005 - 2010 7 March 28th, 2008 10:05 AM
