Authorized Vendor
![]() 2007 Mustang GT
Comp Cams - 2011-2012 Mustang 5.0L Coyote Camshafts - AmericanMuscle.com
It's that time! We've gotten literally hundreds of inquiries about the 2011 & 2012 5.0L Coyote Mustang cams. The wait is finally over! They're in-stock and shipping. Can't wait to bolt these up to our 2011 Automatic to see what it'll do to our current 10.43 @ 130mph. We'll have dyno results and more soon!
Want some specs on them in the mean time? Comp Cams Stage 1 XFI NSR Camshafts (11-12 GT / 5.0L Coyote) • Advertised Duration: 267 • Valve Lift Int: .492 • Valve Lift Exh: .453 • Duration @ .050 Int: 220 • Duration @ .050 Exh: 223 • Lobe Separation: 126 • RPM Operating Range: 1500 to 6800 Comp Cams Stage 2 XFI NSR Camshafts (11-12 GT / 5.0L Coyote) • Advertised Duration: 275 • Valve Lift Int: .492 • Valve Lift Exh: .453 • Duration @ .050 Int: 228 • Duration @ .050 Exh: 231 • Lobe Separation: 126 • RPM Operating Range: 1700 to 7000 Comp Cams Stage 3 XFI NSR Camshafts (11-12 GT / 5.0L Coyote) • Advertised Duration: 283 • Valve Lift Int: .492 • Valve Lift Exh: .453 • Duration @ .050 Int: 236 • Duration @ .050 Exh: 239 • Lobe Separation: 126 • RPM Operating Range: 1900 to 7200 None of these are spring required cams, however ALL OF THEM need the phaser limiter kit, which we'll have up on the site soon. Stage 1 & Stage 2 Cams are compatible with stock gears and stock converter, while the Stage 3 cams need a 3.73 or steeper rear gear ratio and long tube headers. Converter will probably be a good idea in Stage 3 as well, but we'll know for sure once we install them in ours!
Chris Rose | AmericanMuscle.com Toll Free: 866.727.1266 | M-F 9AM-9PM EST | Sat 10AM-4PM EST Bama Hotline: 888.226.9764 | M-F 9AM-5:30PM EST | Sat 10AM-4PM EST Need Help? PM AMShaneLesky for immediate assistance! |
11 Mustang GT
Track times coming soon.
those stage 3 cams look like they will go well with the boss intake manifold.
2011 Mustang GT MT. Ford Racing K springs, Boss intake manifold, JLT Cold air intake, BBR O/R Xpipe, Ford Racing 4.10 gears, TA Rear End Girdle, VMP E85 Tune/BBR 93 Tune. |
thats what i was thinking but we will see what happens with my vehicle replacment 1st
FOR SALE:2010-11 sos triple pillar pod... slight nick in it 115 shipped pm for pics |
2011 Mustang GT
12.3@115ish
Ah yes, but which one will work best with boost.
![]() 4 Cams...32 Valves...5 Liters...This Could Get Fun |
Will there be any way to make a "Ghost Stock Idle tune" with these? Can't wait to see some numbers.
If yo go to comp cams website they have them for all sorts of diff applications
2011 Mustang GT
12.3@115ish
I'm not puttin cams in mine, just curious for those that might ask the question. Mine will hit my goals as soon as I put the pro charger on it.
2012 Mustang GT
2012 Mustang GT Coupe
13.2
That's all I have decided to do. Now if I could quit buying treadmills and stuff it would go a lot quicker. Besides it always seem the first cams to come out end up being the bottom of the barrel in a year.
2012 GT Black on Black MT-82 3.73 JLT Catch Can & Air Raid CAI Hushpower axle backs
#10 | |
Authorized Vendor
The Boss comes with lopey cams from the factory. The stock tune simply "tones them down" like you're saying. Once you put in the track key, it simply lets the cams do their thing. So, yes, the technology is out there.
Authorized Vendor
These cams are going to be fine for boost. Just like in the 05-10's, there are boost-specific cams and then there are cams for N/A. I've tuned plenty of N/A cams (like Hot Rods and Thumpr Cams) on forced induction cars. You lose maybe an extra .5lb of boost maximum, not a big deal at all. Worth it, if you're after the sound of an N/A cam but power of a supercharger/turbo/nitrous.
2011 Mustang GT
12.3@115ish
I've gone back and forth between the 2...I can't make up my mind so I'm just going to start collecting parts that I'll need either way. 80 lb/hr injectors, some spark plugs, which I've been digging heavily into, a clutch...thanks on the info on this Chris, I'll be placing that order in about 2 weeks, shocks, ya know stuff like that. The cams would be a nice addition...although at $1400...WOW!!! That's steep lol.
11 Mustang GT
skunk why dont you just slap a nice bottle in the trunk and spray the shit out of the coyote.
2011 Mustang GT
12.3@115ish
Too many bad experiences with the drugs. Over dosed a couple motors a few years back and vowed to never take the "easy" way out again.
ive got whole n20 setup that can be run safely including gauges that will shut it down if you get to lean or fuel pressure drops
#16 | |
2011 GT / 72 Maverick
12.12 @ 114
You ran too big of a pill and ran out of fuel? Not dyno tuned? Not properly installed? It's almost impossible to "overdose" a motor on nitrous these days... Nmu's shut off the nitrous if your fuel pressure drops Window switches only allow nitrous to activate at your programmed rpm ranges per gear wot switches make it impossible to introduce nitrous unless your at wot I've been playing and spraying for years with no negative effects. As long as you set it up correctly and use it properly its as or more effective as any other type of F/I and just as safe. |
11 Mustang GT
yeah bottle fed gt is right skunk.. nitrous is super safe dude.. im willing to bet that its just as dangerous or even less dangerous than any blower or turbo setup when you stay under when you stay around 550whp on this motor.
2012 Mustang GT
I don't know, I've just never cared for using nitrous. I'm looking at a remote mounted twin turbo setup now that I will probably stick with. Running that at around 8-9 lbs of boost and I should be happy for a while.
11 Mustang GT
i rather have twins or even single turbo or a any blower instead of nitrous.. but i also rather have 5000 bucks left in my bank account and have about the same power. for the limits of this motor is really not worth it to get twins as you wont benefit much from them because with a small single turbo you will be able to push the motor to the limit.. now if you have a built motor and want 1000whp i understand why you would need twins.. because you would need to have a big single turbo that will have some lag and with twins you wont have as much lag. for a stock coyote i think that twins is just a waste of money.
Yes, I am your Daddy
2011 Mustang GT
12.2 w/o N20
![]() iTrader: 3 reviews
theres already a twin turbo setup for our 5.0s?
Threads Similar to: Comp Cams - 2011-2012 Mustang 5.0L Coyote Camshafts - AmericanMuscle.com
| Edelbrock E-Force Supercharger for 2011 Mustang GT @ AmericanMuscle | AMChrisRose | American Muscle | 0 | March 21st, 2011 12:59 PM |
| 2011-2012 Mustang Boss 302 Intakes in stock! | LRSjmac | LatemodelRestoration.com | 0 | February 23rd, 2011 02:02 PM |
| 2011-2012 Mustang 5.0L Blue Coil Covers Now Available! | LRSjmac | LatemodelRestoration.com | 0 | February 22nd, 2011 02:14 PM |
| AmericanMuscle 2011 Mustang GT Goes 10.93 @ 125 MPH! | AMChrisRose | 2011+ | 27 | December 3rd, 2010 12:27 AM |
