PowerPack 6 Distribution Center in stock @ Atomic Performance
Go Back   Forums at Modded Mustangs > The Marketplace > Authorized Vendors > Atomic Performance
Old April 24th, 2008, 05:01 PM   #1
1997 Ford Mustang Cobra
11.21@126
Atomic Performance is on a distinguished road
Hey guys, We just got these back in stock and they are ready to be shipped. The price is 149.99 and you get free shipping. Take advantage of the $10 off for being a forum member.
If you are tired of splicing into your factory wiring, here's a great product that allows you to run all of your accessories in a stand alone unit.
Let's face it - The manufacturers of cars generally don't build extra room for accessories in their wiring systems. The circuits are designed to carry a certain power load. When you add items, you risk blowing fuses and leaving yourself stranded. Don't forget that you have to use taps and other methods to cut into the factory harness.
Eliminate all that mess with a Power Pack 6 Distribution Center! All you need to do is mount it securely on the supplied brackets, hook it up to you battery, add your accessories and fuses and you're in business! You can distribute up to 35 amps of power to each of the six individual circuits. They're also easily turned on or off with box mounted rocker switches.
Features and Benefits
* Eliminates the need for splices and modifications to the factory wiring harness
* Can power up to 6 circuits, and up to 35 amps of power on each circuit
* Uses standard ATO blade style fuses available at any auto parts store
* You can also switch the ground so there is no need to run power to a switched device
* Has a small footprint, measuring 7"x7"x4", allowing it to be mounted almost anywhere!
* Completely servicable with easily replaced relays
* Marine quality stainless steel studs and hardware with aluminum box for absolute corrosion protection
* Wiring chart laser engraved on the box allowing for quick reference. Need to know what gauge wiring to use? It's engraved on the box and will not wear off over time like pad printing.
* Simple installation!
Examples of uses
* Gauges
* Nitrous Systems
* Ignitions Systems
* Line Lock
* Aftermarket Stereos
* Navigation Systems
* External or Interior Lighting
* Anything Electrical!
Application: Universal
Here is a link to it on our site.
PowerPack 6 Distribution Center - ATOM-PWRPCK6
Threads Similar to: PowerPack 6 Distribution Center in stock @ Atomic Performance
Atomic Performance BLACJAC 2005 - 2010 1 April 15th, 2008 01:05 AM
Powerpack or 4.2 99v6stang V6 Mustangs 18 March 9th, 2007 11:31 AM
performance cam/stock heads? 1990CA50 5.0 Mustangs 17 February 6th, 2007 02:02 PM
