Fore Precision Works Triple Pump Fuel Hat In Stock
Go Back   Forums at Modded Mustangs > The Marketplace > Authorized Vendors > Atomic Performance
Old May 28th, 2008, 04:21 PM   #1
1997 Ford Mustang Cobra
11.21@126
Atomic Performance is on a distinguished road
Hey Everyone, We are excited to announce that we just got the NEW Fore Precision Works Triple Pump Fuel Hat in stock. They are $420 shipped to your door. You will get the $10 off for being a forum member.
Need more fuel pump in your 03-04 Cobra? Don't want to weld in a sump or employ any other work around? Here's the solution! You GT owners don't need to worry, either as you can get a an '03 - '04 Cobra fuel tank and you're ready to go! It comes configured as a 2 pump setup but can be converted to a three pump by simply adding the conversion kit above.
Makes Ford GT supercar fuel pumps a BOLT IN installation. No more welding, caulking, or deforming your floorpan to clear pump outlets. Install GT pumps in a matter of minutes, rather than days. Accommodates up to three Ford GT supercar fuel pumps, triple, dual or single FPDM (Fuel Pump Driver Module), and OEM fuel sending unit. PPRV and restrictive in tank "Y" is eliminated. Pumps outlets are designed for optimal fuel delivery. Three pairs of 12 gauge, gas blocked conductors for fuel pumps for direct wiring to FPDM(s). Allows your Ford GT pumps to operate without losses from undersized OEM wires. (conductors conform to MIL-W-16878/4). Retains OEM fuel level sending unit with 18 gauge through conductors. (MIL-W-16878/4). No welding or caulk used in assembly or manufacturing. Full billet components use o-rings, OEM seals, and epoxy sealed through conductors. Submersible fuel line included. (conforms to SAE 30R10). Assembly is pressure tested prior to shipping.
Please let me know if you have any questions or would like to place an order. Thanks, AP
Here is a link to the hat on our site:
FPW 2003 - 2004 Cobra Triple Pump Fuel Hat AN -8 Outlet - FPW-F0304FHAT
Threads Similar to: Fore Precision Works Triple Pump Fuel Hat In Stock
Fore Precision Walbro Fuel Pump Hat! Derek@DRI 99-04 0 May 28th, 2008 12:29 PM
Fuel pump question. Stock GT pump to GT (supercar) pump. Nate's4.6 99-04 15 May 14th, 2008 03:25 PM
New Fore Precision Fuel Rails Derek@DRI 4V / SVT 0 May 1st, 2008 06:21 PM
