Moderator
Audio help
Alright I see that all of us are into trying things on our cars ourselves and sometimes we might fuck something up. Well let me tell you with the electronics part some are simple and some are you should just leave to a Pro. It is good to be able to say that you did it yourself but there are just soo much involved in the electronics side. Like if you were to do an alarm some of our vehicles need to be diode isolated and relays and things like that. If you are trying to do something yourself let me know what you are trying to do and I can tell you if it is gonna be easy or if it is something that should be left to a professional. Ive been doing this for 5 years since I left the military to continue school and I got my boss that has been doing it for about 15 years. So let me know cause I have all sorts of resources at my disposal like diagrams and tech notes on exactly what needs to be done. So if you need be just post here or just PM me.
Basically, dont be afraid to ask for help. Just dont go blowing me up LOL
![]() ![]() BUILD 2 IN PROGRESS |
Moderator
check this out
WIRING INFORMATION - FORD / MUSTANG / 1999 / Remote Start 12volts yellow & lt. green/purple + ignition harness Starter white/pink + ignition harness Second Starter N/A Ignition red/lt. green + ignition harness Second Ignition N/A Third Ignition N/A Accessory gray/yellow and red/black + ignition harness Second Accessory black/lt. green + ignition harness Keysense black/pink - ign harn, 26 pin plug, pin 9 at GEM Notes: The GEM (Generic Electronic Module) is located above the driver kick panel. Power Lock lt. green + 20 pin plug, pin 20 at GEM Notes: The GEM (Generic Electronic Module) is located above the driver kick panel. Power Unlock purple + 20 pin plug, pin 18 at GEM Notes: The GEM (Generic Electronic Module) is located above the driver kick panel. Lock Motor red/white 5wi 20 pin plug, pin 9 at GEM Notes: The GEM (Generic Electronic Module) is located above the driver kick panel. Unlock Motor red/orange 5wi 20 pin plug, pin 7 at GEM Notes: The GEM (Generic Electronic Module) is located above the driver kick panel. Parking Lights+ brown + 26 pin plug, pin 7 at GEM Notes: The GEM (Generic Electronic Module) is located above the driver kick panel. Parking Lights- white/black - 26 pin plug, pin 11 at GEM Notes: The GEM (Generic Electronic Module) is located above the driver kick panel. Hazards same as turn signals Turn Signal(L) lt grn/wht(F), lt grn/org(R) + steering column Turn Signal(R) wht/lt blu(F), org/lt blu(R) + steering column Reverse Light black/pink + 26 pin plug, pin 20 at GEM Notes: The GEM (Generic Electronic Module) is located above the driver kick panel. Door Trigger yel/black (L), gray/red (R) - 20P plg, pin 13 & 5 at GEM Notes: Use yellow/black for the driver door trigger and gray/red for the passenger door. Use both wires and diode isolate each from the GEM module, refer to DirectFax document 1076 for wiring information. The GEM (Generic Electronic Module) is located above the driver kick panel. Dome Supervision black/white + 20 pin plug, pin 3 at GEM Notes: The GEM (Generic Electronic Module) is located above the driver kick panel. Trunk/Hatch Pin brown/white - 12 pin plug, pin 3 at GEM Notes: The GEM (Generic Electronic Module) is located above the driver kick panel. The hatch pin needs to be diode isolated from the GEM module. Refer to DirectFax document 1076 for wiring information. Hood Pin N/A Trunk/Hatch Release pink/lt. green - 26 pin plug, pin 25 at GEM Notes: The GEM (Generic Electronic Module) is located above the driver kick panel. Power Sliding Door N/A Factory Alarm Arm arms on lock with door open Factory Alarm Disarm dk. green/purple - 20 pin plug, pin 16 at GEM Notes: The GEM (Generic Electronic Module) is located above the driver kick panel. Disarm No Unlock see factory alarm disarm Tachometer NOT red or white/lt. blue ac ignition coil or coil pack Wait to start N/A Brake Wire red/lt. green + brake pedal switch Parking Brake purple/yellow or lt. blu/blk - 12 pin plug, pin 4 at GEM Notes: The GEM (Generic Electronic Module) is located above the driver kick panel. Horn Trigger yellow/lt. green - 26 pin plug, pin 12 at GEM Notes: The GEM (Generic Electronic Module) is located above the driver kick panel. Memory Seat 1 N/A Memory Seat 2 N/A Memory Seat 3 N/A Interface Module: Category: Immobilizer Bypass Required: Yes Type: PATS Part #: 1100F Alternate Part1 #: 1100X Alternate Part2 #: 555PW/555FW Alternate Part3 #: 556UW Alternate Part4 #: DesignTech 20402 Alternate Part5 #: DesignTech 29402 Notes: When using the 1100X, a software change to 1100FM is needed. Smart Starter Kill Relays: Not Available
Moderator
everything i have is make, model, year, specific
Look Ma! My First Post!
Hi. I have a '99 GT with a Mach 460 system. I'm having trouble finding spec's. About all I've come up with is that the system has 3 amp's, it outputs 230 watts, and it has built in cross-overs. What I want to know is what is the impedance of the speakers. My passenger door woofer went out and I don't want to replace it with an aftermarket (i.e. 4 ohm) speaker without knowing the original load impedance - otherwise I could blow an amp.
Thanks. |
Moderator
the door speakers are 4 ohm while the subs are 2 ohms
hi, i have an 02 gt w/ the Mach 460 audio system. i am installing rockford fostgate subs/amp. everything was going ok till i spliced into the data cable going to the rear deck (i used this link http://www.mustangworld.com/ourpics/fcar/despeeds1.htm). Now, everything electronic works on the car... except for the head unit. i tested the radio fuse, but it was fine. there is simply no power coming to the head unit. what do i do?
"America is all about speed. Hot, nasty, bad ass speed." Eleanor Roosevelt, 1936
i do EVERYTHING my self... it also helps to have professionally licensed electrical enginers as parents. but yea... mostly my self.
Threads Similar to: Audio help
| audio | d2daj86 | Audio/Video | 3 | October 29th, 2007 11:35 AM |
| Ok Need Some Car Audio Help Here | mixedbreed02gt | Audio/Video | 4 | October 6th, 2007 10:32 AM |
| Audio set up? | Slowbra_12 | 96-98 | 3 | September 18th, 2007 01:02 AM |
| v6 audio | Narcotics | Audio/Video | 39 | July 12th, 2007 01:45 PM |
| audio | bryanrocks907 | V6 Mustangs | 3 | July 23rd, 2006 09:11 PM |
