sub and amp install
Old December 27th, 2006, 03:04 PM   #1
MM's Resident Ricer
GreenFaleen's Avatar
2006 Scion tC
13.001@113
sub and amp install
I just got a 12 inch sub and a amp and I was wondering how to install it? I went a few places and they all want like 100 bucks to do it so I figured I'd do it myself. Any help would be appreciated thanks.
NCMM #9
Old December 27th, 2006, 11:00 PM   #2
Moderator
wraitherx's Avatar
'99 SVT Cobra
wraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud of
iTrader: 11 reviews
do you have the mach system???? do you have and aftermarket deck or stock let me know what you got so i could help you out, I know the ins and outs of car electronics I just helped Bob17830 hook his up so if you want to ask him how his is doing
BUILD 2 IN PROGRESS
Old December 27th, 2006, 11:52 PM   #3
MM's Resident Ricer
2006 Scion tC
13.001@113
Umm no mach system at all I have a sony after market head unit and jl audio speakers all around the car.
NCMM #9
Old December 28th, 2006, 04:22 AM   #4
97TunedMustang's Avatar
97TunedMustang is on a distinguished road
Send a message via AIM to 97TunedMustang
Do you mean like physically running wires through your vehicle for your amplifier and subs? you'll need a amp wiring kit for one thing. probably an 8ga will do with just one 12". Youll need to be able to run the power wire through the firewall. if your comfortable with getting behind your HU and running wires around the footwell and under the door sills then you should be fine.
95 Civic Ex, FnF1's, Morimoto Mini h1 retrofit,
GSR, bbk intake, BDL tb, 57trim t3/t4 8psi, 297whp
96 Civic Ex 2dr, G3 HID retrofit, FnF type 1's, Si cluster, Obd1 Z6 swap
Old December 28th, 2006, 01:23 PM   #5
MM's Resident Ricer
2006 Scion tC
13.001@113
ok yeah I was just wondering where I need to connect all the wires and how to run them from the amp to the sub. Also where can you get one of the wiring kits?
NCMM #9
Old December 28th, 2006, 04:27 PM   #6
You might be able to find a fairly cheap 8 or 5ga wiring kit at walmart for like 30-40$ but make sure it has the Power wire, ground wire, rca's, remote wire, and extra speaker wire. You for sure can find the a good rockford fosgate kit at either circuit city or best buy but your looking at $100-$150. if it was me and you are able to i'd get one from ebay. they are phenomenally cheaper. heres one for $27 shipped.
http://cgi.ebay.com/ebaymotors/8-Gau...63563921QQrdZ1
You'll want to run the power wire for the amp on one side of the car say down the driver side door sill. and then the rca's and remote turn on the lead down the passenger side. it helps cut down on interference. Youll wanna pull out your deck and plug in the rcas to the rca output on the HU and connect the amps remote turn on lead to the remote turn on output from the HU. Make sure you ground the amplifier within 6 feet of cable or less to somewhere in the trunk. do NOT run the ground back to the battery.
Old December 28th, 2006, 04:29 PM   #7
MM's Resident Ricer
2006 Scion tC
13.001@113
ok thanks.
NCMM #9
Old December 29th, 2006, 10:50 AM   #8
2000 Honda C/1968 Mustang
68pony is on a distinguished road
Send a message via AIM to 68pony
Damn son, last night sucked. Hope nuimage can help fix our mess.
In case anyone is wondering, we got everything wired and it worked except for the CD player. We worked on that HU till around 3 AM. GF might not be awake for a while......
Originally Posted by Horseshoeing
In a 1965 Mustang the traction control is the gas pedel.
I need to drive my Mustang more......
Old December 29th, 2006, 02:09 PM   #9
MM's Resident Ricer
2006 Scion tC
13.001@113
OK to explain more it is a I am going to rip my hair out situation. We had everything wired in right it all worked sub sounded nice, but my head unit reset it self with a cd in and now doesn't want to take a cd if anyone know what can fix this it will be greatly appreciated. HU is a cdx-m600 from sony.
NCMM #9
Old December 29th, 2006, 10:19 PM   #10
Didn't you say that you got it fixed? If so, does it still hit good? Let us know. I lost alot of sleep last night trying to hook that shit up.
Old December 29th, 2006, 10:54 PM   #11
MM's Resident Ricer
2006 Scion tC
13.001@113
lol yeah sry about that. Yeah it sounds awesome gotta get that dyno mat on my license plate and we have almost no rattle
NCMM #9
Old January 3rd, 2007, 04:52 AM   #12
scubasteve041186's Avatar
2004 mustang 40th annv.
scubasteve041186 is on a distinguished road
Send a message via MSN to scubasteve041186
haha good to know. so you got the cd out right? lesson learned though take the cd's out b4 working with the head unit
Old January 3rd, 2007, 04:54 AM   #13
should have only take you 30 minutes to hook up though.. well it should be easy now. did you pop off the back seat and what not? to hide the extra cable? the bottom portion is just clips. just get a butter knife and run it along the bottom of the ack seat till it stops * somewhere in the middle* and just push on that tab with the butter knife. there are two tabs one on each side. otherwise all the cables are labeled and should be easy.
Old January 3rd, 2007, 03:28 PM   #14
MM's Resident Ricer
2006 Scion tC
13.001@113
yeah it wasn't hard we just goofed off and had some trouble getting some panels off. But yeah seats came out easy once we got the rubber mallet into it.
NCMM #9
Old January 3rd, 2007, 06:29 PM   #15
you make it sound like we had no clue what we were doing. Oh wait, we didnt. No it wasnt that bad. besides it got me out of my house for most of a week. That is a good thing too. But next time, we can do it quickly.
Old January 3rd, 2007, 09:21 PM   #16
MM's Resident Ricer
2006 Scion tC
13.001@113
yeah and we will make sure the ground wire they give us is actually crimped (damn cheap install kit)
NCMM #9
Old January 4th, 2007, 12:43 AM   #17
trueballerisme is on a distinguished road
do u guys know where i could get sum one to make me a fiberglass amp enclosure...
and wut color neons would u guys put in it. im thinkin like red in the bottom and blue on the red...
Old January 4th, 2007, 12:40 PM   #18
Not off the top of my head. you might try your local audio shop. they might be able to help you.
Im not a fan of neons, so i cant help you there either. sorry
Threads Similar to: sub and amp install
How to Install a Top TurboLX General Tech 8 March 1st, 2011 12:46 PM
*^$ HOW DO I INSTALL *^$ mustang1072 V6 Mustangs 4 September 27th, 2007 11:45 AM
SCT 3 install ? yamahammer 2005 - 2010 3 September 21st, 2007 08:32 PM
CAI install jabrennan V6 Mustangs 22 March 10th, 2007 02:30 AM
HID install help geekstang 99-04 1 August 26th, 2006 04:17 PM
