2006 Mustang GT
connecting Sub AMP to stock Stereo?
hey guys, i just got a 06 GT and i want to get my subs in it. the factory stereo is good for now, but i want to get more bass. is there a hook up on it to run an AMP or do i have to do a high level input to the amp from the rear speakers?
thanks for any info!
![]() JSTARS 4 LIFE |
Moderator
you will need a line out converter and yes tap into the rear speakers.
![]() ![]() BUILD 2 IN PROGRESS |
Moderator
here are the colors for you car, you can either get them behind the radio or go at the rear speakers themselves.
Battery LIGHT GREEN/VIOLET (+) RADIO HARNESS Accesory GRAY/YELLOW (+) RADIO HARNESS Ground BLACK/ORANGE (-) RADIO HARNESS LF Speaker (+) ORANGE/LIGHT GREEN LF Speaker (-) LIGHT BLUE/WHITE RF Speaker (+) WHITE/LIGHT GREEN RF Speaker (-) DARK GREEN/ORANGE LR Speaker (+) GRAY/LIGHT BLUE LR Speaker (-) TAN/YELLOW RR Speaker (+) BROWN/PINK RR Speaker (-) ORANGE/RED
2006 Mustang GT
thank you very much. i appreciate it! do you know if it sounds bad? i'm guessing the signal wouldn't be very great.
![]() JSTARS 4 LIFE Last edited by CS2JZ; January 8th, 2009 at 07:39 PM. |
Moderator
the signal will be fine, it would sound better with an aftermarket radio cause you'll have more control over the hertz, gains, etc... but you will be fine.
Depending on the LOC you can control frequency, gain and load of other things. Stay away from the scosche one's they suck. You may find that you will need one with a power wire and/or ground wire. They can be a major PITA.
2006 Mustang GT
well, i can't get the console apart right now. where can i find another accessory wire?
Resident DJ
'01 Cobra Vert.
What's stopping you from getting the console apart?
Moderator
first off lift up the surrounding trim ring around the shifter, open your arm rest and I think that there are 2 screws holding it down, remove those two. then pull up on the whole center piece (with the cupholders) it will pop up, also make sure to have your ebrake up it just makes it alot easier. now from there pull on the plastic trim pieces to the left and the right of your radio (it will pop off but might be kind of tight just be careful) then take the radio trim off and unplug the connectors. I believe that there are a total of either 4 or 6 9/32 screws holding the radio in remove these then you are done.
2006 Mustang GT
wow... thanks. i tried to search for a how-to. but didn't have any luck. everything it all bolts and no phillips, i didn't have the proper tools at the time. my car was too messed up to drive to get tools and i wanted to get it finished. but i will follow your description and get it done right.
eventually i want to get one of them Kenwood in dash GPS and DVD receivers i'm gonna be takin some pics tooooooday!!! ok, and whoever said the sosche stuff is crap, they were right. i'm using their line converter
![]() JSTARS 4 LIFE Last edited by CS2JZ; January 9th, 2009 at 02:27 PM. |
Moderator
no problem
2006 Mustang GT
sweet. it's all hooked up and it sounds ok... i expected it to be a little crappy. but at least i have more bass now. thanks for the help guys, couldn't have done it without ya.
Moderator
good to hear, enjoy
2006 Mustang GT
oh, i forgot to mention. i can't find the AUX input! do i not have one? it has the shaker500. i found a harness with a small clip sitting under the cup holders that wasn't plugged in to anything.
Moderator
im dont think that your car came with an auxillary feature unless it is in your center armrest.
2006 Mustang GT
Dang. I guess I just have to upgrade soon. I didn't see anythin under the arm rest.
Look Ma! My First Post!
где взять игры для Psp ?
доброго времени суток!
скажите, кто нибудь знает, где бы найти игры для Psp ? |
Threads Similar to: connecting Sub AMP to stock Stereo?
| Stock 03 Stereo | Genevieve! | Audio/Video | 13 | March 23rd, 2010 06:17 PM |
| 2001 gt mach stereo sub & amp install | gwilkrrs | Audio/Video | 6 | June 1st, 2008 11:29 PM |
| Remove stock stereo 2004 V6 coupe | fernando1162 | New Members Introductions | 0 | December 27th, 2006 11:12 PM |
| Connecting Stock Tach to Mallory 3770401 Unilite Distributor | 83 5.0 | 5.0 Mustangs | 2 | October 5th, 2006 08:39 PM |
| stock stereo install | 94mustanggt | Audio/Video | 3 | April 16th, 2006 11:14 PM |
