Radar Detector Wiring
LinkBack (1) Thread Tools
Old February 6th, 2009, 04:38 PM   1 links from elsewhere to this Post. Click to view. #1
MM's Official Lucifer
goren813's Avatar
'00 3.8L & '05 4.6L
Has anyone wired a radar detector behind the dash?
So far I think I'm planning on just getting a relay and running it to the radio. My goal is to have the detector on only when the car is on. As it is now it simply plugs into the 12volt, which as we all know stays on when the car is off. I'd also like for it to look cleaner instead of the wire hanging down past the head unit.
Thanks for any input.
Old February 6th, 2009, 04:56 PM   #2
Resident DJ
Lefty's Avatar
'01 Cobra Vert.
iTrader: 12 reviews
I just wired into a 12v source that was triggered when the key is turned for mine on my GT. I don't remember where I tapped into tho...ask Wraither on here. He'll give you an answer in about .0362 seconds.
Old February 6th, 2009, 11:20 PM   #3
Moderator
wraitherx's Avatar
'99 SVT Cobra
wraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud of
iTrader: 11 reviews
, i can give you the wires colors on sunday as im out of town right now.
BUILD 2 IN PROGRESS
Old February 7th, 2009, 12:40 PM   #4
goren813's Avatar
'00 3.8L & '05 4.6L
Much appreciated. Reps will be given accordingly.
Old February 7th, 2009, 03:00 PM   #5
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
I put mine on the drivers side corner and ran the wire under the edge of the dashboard, down the side and into the fuse block. There are a couple ground screws in there you can use. Put a ring connector on the end of ground wire and secure it to the screw. Take the hot wire for the detector and strip it, then wrap it around the post of the radio fuse and reinsert the fuse into the block. Now everytime you turn on your cars ignition, the detector will come on. It has a neat and clean appearence as well.
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Old February 7th, 2009, 03:03 PM   #6
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
If you don't have a ring connector, just strip the ground wire and make a loop long enough to go around one of the ground screws a couple times. Back one of the ground screws out a little bit, then wrap the wire around it a couple of times. When you tighten the ground screw back up the wire will stay put until you loosen it again.
MODS IN GARAGE
NCMM ORIGINAL
Old February 8th, 2009, 02:03 AM   #7
goren813's Avatar
'00 3.8L & '05 4.6L
Thanks, I'll let you know how it goes.
Old February 8th, 2009, 11:06 AM   #8
Resident DJ
Lefty's Avatar
'01 Cobra Vert.
iTrader: 12 reviews
You do know you should have your radar detector mounted high enough on the windshield so it can shoot a signal out of the rear window right?
Old February 8th, 2009, 11:11 AM   #9
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
That's what I always thought too, but the directions that came with this one said it was best to mount low on the windshield and elevating it would actualy decrease it's effectiveness.
MODS IN GARAGE
NCMM ORIGINAL
Old February 8th, 2009, 01:47 PM   #10
Resident DJ
Lefty's Avatar
'01 Cobra Vert.
iTrader: 12 reviews
Mount it just enough where it can go through the bottom of the rear windshield.
Old February 9th, 2009, 01:28 AM   #11
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
alright here you go,
if you want to catch power at the ignition harness, but you will have to make your own ground
Ignition 1 RED/LIGHT GREEN (+) IGNITION SWITCH HARNESS
if you want to go behind the radio
Ignition BLACK/PINK (+) RADIO HARNESS
Ground BLACK/GREEN (-) RADIO HARNESS
BUILD 2 IN PROGRESS
Old February 9th, 2009, 10:39 AM   #12
Resident DJ
Lefty's Avatar
'01 Cobra Vert.
iTrader: 12 reviews
Always representin'
Old February 9th, 2009, 03:52 PM   #13
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
Always representin'
BUILD 2 IN PROGRESS
LinkBack to this Thread: http://www.moddedmustangs.com/forums/audio-video/109104-radar-detector-wiring.html
Types of Radar Detectors This thread Pingback February 7th, 2009 07:16 PM
Threads Similar to: Radar Detector Wiring
hard wiring radar detector in 2007 gt tweavtheboss 2005 - 2010 10 June 12th, 2008 08:45 PM
Just got a new radar detector MustanG_guy17 The Clubhouse 10 May 8th, 2008 09:35 PM
Radar Detector CTown Stang Audio/Video 2 December 29th, 2007 09:56 PM
Radar Detector o3gtdgs 99-04 9 October 9th, 2006 03:09 PM
