Stock Speakers/Aftermarket Amp
Old March 6th, 2009, 03:53 PM   #1
moneygreenstang's Avatar
2001 Mustang GT
moneygreenstang will become famous soon enough
Can i use the stock component mach 460 speakers with my aftermarket amp and how would i have to wire them to work? i wont be getting my old speakers shipped from home for a week or two
01 GT Vert - Triple Black - 2v 5.4 270/340
00 Lightning - Triple Black - 2v SC 5.4 400/500
Brand New Tubular UCA and LCA set for sale PM me
Slightly Used 05-09 Halo Headlights for sale PM me
Old March 6th, 2009, 06:12 PM   #2
mxnate116's Avatar
SVTfocus, F250
mxnate116 is a jewel in the roughmxnate116 is a jewel in the roughmxnate116 is a jewel in the roughmxnate116 is a jewel in the rough
im not sure if your aftermarket amp will handle the ohm load of the stock speakers
generally most stock speakers run 1-2ohms and most amps run 4 ohms some 2 and i have yet to see a 2ch that is 1ohm stable.
and im not sure you could even wire them to work right i dont think the stock system has a dedicated crossover but im not 100% positive
Old March 10th, 2009, 09:49 AM   #3
Moderator
wraitherx's Avatar
'99 SVT Cobra
wraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud of
iTrader: 11 reviews
if the system is amplified they can be anywhere between 1-3ohms, usually 2-3ohms. if they arent then they are usually 4 ohms. ive only seen a handful of cars that are running 1 ohm setups and they are the exotic cars and the sub is the only thing at 1 ohm. most manufacturers will not put that kind of system into a car as it will cost alot of money to make a system, let alone and amp, that can run flawlessly at 1 ohm
BUILD 2 IN PROGRESS
Threads Similar to: Stock Speakers/Aftermarket Amp
aftermarket speakers in a mach-460 system? BrandonJD25 Audio/Video 3 March 2nd, 2008 08:30 PM
How Much Better Will These Be Over Stock Speakers? Avaric3 Audio/Video 4 December 19th, 2007 05:18 PM
New Amp and Speakers superkeege Audio/Video 13 October 4th, 2007 08:06 AM
